Jim (guest)
Guest
Posts: n/a
Can I set the cam timing,without using the dial indicator gauge ?let me know,please.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-10-2013, 10:33 PM
You can but there is a very good chance you will be slightly off regarding the valve timing.
- Kerry
vince_wa
I do not see how you could get the cam timing even close without a dial indicator. The dial blog and indicator is a cheap tool given the danger and consequences if you get it wrong. Even with the dial indicator it still took me a hour to get it correct
Garage - 1987 911 widebody
Old 08-10-2013, 11:32 PM
LakeCleElum's Avatar
Not recommended for sure...
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 08-11-2013, 03:45 AM
Fleabit peanut monkey
Bob Kontak's Avatar
I would say there is absolutely no chance that you would even be close.
You set cam timing in two places.
Both sides will be a far ways away from being correct and the two sides will not match each other.
1981 911SC Targa
Old 08-11-2013, 06:11 AM
just use your eyecrometer
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 08-11-2013, 06:30 AM
If one is asking that question, I would wonder how much one actually knows about what one is doing? Are you also torquing without a torque wrench?
John Thompson
Eugene, Oregon
Old 08-11-2013, 08:46 AM
Home of the Whopper
If you do, please paint the fan red so I know to stay away if you decide to sell.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 08-11-2013, 01:44 PM
tharbert's Avatar
Of all the special tools needed, the Z block/dial gauge is probably one of the cheapest to DIY. Do a little searching. Dial gauges are cheap at places like harbor freight. There are a number of low tech, low budget Z blocks in several threads here. Bet you could put one together for less than $25.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 08-12-2013, 04:57 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Z block is unavailable here, can you point me to where I may be able to find/build a set of tools to do the cam timing? It's the one thing (so far) I haven't done myself.. Just need a Z Block and dial indicator?
Gary R.
Old 08-12-2013, 05:32 AM
GaryR's Avatar
He won't need to, it will be the engine with the fan that no longer spins...
Gary R.
Old 08-12-2013, 05:33 AM
tharbert's Avatar
Red fan haters aside...
Here's the post that has dimensions and pictures of the low tech, highly functional DIY Z blocks I mentioned.
Here are a couple other Pelican Parts threads on the same topic:
z block alternative?
z-block dial gauge holder for cam timing
Z block
72 911T 2.4 MFI
Old 08-12-2013, 06:19 AM
GaryR's Avatar
I sent the dimensions to a CNC buddy, lets see what he comes up with. Are all dial indicators the same diameter shaft (.375)?
Gary R.
Old 08-12-2013, 06:29 AM
tharbert's Avatar
9.52mm or ~3/8" = standard stem size so .375 will fit nicely with a thumb screw to secure at the stem.
72 911T 2.4 MFI
Old 08-12-2013, 07:49 AM
