transmission shift issue
i recently had an issue with the synchronizing ring on first gear. I dropped the engine out and rebuilt the first gear. After reassembly the transmission will not shift into rd or th gear with the car moving. When attempting to shift into rd or th you will hear a grinding noise as if the gears were not meshing. When parked there is not issues moving between gears and I can start in nd and shift to rd when moving but cannot get into th.
any suggestions? |
Fleabit peanut monkey
Proof reading is a good thing. Look at your post. What year 911?
Did you align your shifter after the trans was back in?
1981 911SC Targa |
sorry 1978 911 and i did align the shifter post installation
thanks |
Under the radar
Made sure the detents were all in their proper place?
Replace the slider with the new syncro?
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Under the radar
Are you saying that he didn't replace the slider? And could that be the cause of his problem?
That depends. Some pictures would help.
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 08-11-2013 at 06:20 PM.. Reason: rephrased |
I don't know what rd and th gear mean!
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
More than likely he is saying 3rd and 4th gears. Sounds like a coupler adjustment is needed.
Gary Kozun 83 911SC Cabriolet |
