first motor drop for head studs. what tools?
i am going down to short block. lower steel head studs, re seal, heads re-work. i have a 1982 911 sc. 48, 000 miles.
i have all the average auto tools. air and hand . PORSCHE: cam holding tool spark plug tool stud removing tool cis gage set porsche motor stand mount ps. with the low mileage should i remove pistons with the barrels? i have read a lot of other threads and feel i can do this. thanks to everyone for what i have learned so far..... thanks carl
1982 guards red 911 sc work in progress
Post this in the Rebuilding forum and you will get a lot more info:
911 Engine Rebuilding Forum - Pelican Parts Technical BBS Do you have Wayne's Book on engine rebuilding? That's a good start.
'82 SC 3.0L Targa, Chiffon/Brown “It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche Last edited by SchnellSchweitz; 08-24-2013 at 04:57 PM.. |
ROW '78 911 Targa
Buy Wayne's engine rebuilding book. It has a great list of tools in it along with most of the special instructions and specs you will need.
books
i have both Waynes books and the Bentley book. i just do not want to buy tools i will not use but want to have the ones that really work. i know that sometimes people have found ways to make things work easer. i want those tools. thanks ...carl
Fleabit peanut monkey
I have lots of tools I can loan you. Since you don't have 3 million posts, you can give me a deposit and then I will return.
Indicators for cam timing and crank play Tools for setting valves Camshaft (old style) crows foot and special socket. Don't know when they switched over. Special off set tool for intermediate shaft (I think that is what it is for) They are sitting in my tool box and they are idle. Don't mind helping a bro. Advise.
1981 911SC Targa |
Bob, thanks. i will keep you on my list. this is my first porsche build. this should be fun. again thanks....carl
If you're going to replace the lower studs or if any are broken the cylinders will most likely have to come off.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
