CBRacerX's Avatar
Speedometer Adjustment for tire size?
http://www.abbott-tach.com/era.htm
Has anyone tried this device on the G-50 911's?
Looks like an easy way to get the speedo accurate again, if compatible with the 911 signaling. I know this works on the 944 platform.
Thanks,
Chris
Old 08-08-2002, 06:18 AM
Cool
CBR..never used anything like that, but I did adjust my speedo. I matched my speedo against a car with cruse control on at 30mph, 60mph, and 70mph..will check it again when I get a smog test in the shop ............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-08-2002, 06:43 AM
I am having speedo problems as well and wonder if this might correct it also. I have an 83 SC and my speedo is running 9 mph fast at 60 mph even though I have stock tires, gear ratio, etc. Speedo shops here in Salt Lake are baffled. Is there an adjustment they just don't know about?
Old 08-08-2002, 08:06 AM
Irrationally exuberant
ChrisBennet's Avatar
How did you adjust your speedo?
-Chris
Early_S_Man's Avatar
Porsche Crest
The 911 electronic speedos from 1976 - 83 have a trimpot on the circuit board.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-08-2002, 08:17 AM
FlaCarrera's Avatar
And, lest we not forget, high reading speedos are racking up odometer miles faster than normal. Where is the trim pot again?...which circuit board?
Ted
86 Carrera
Old 08-08-2002, 08:24 AM
Originally posted by Early_S_Man
The electronic speedos have a trimpot on the circuit board.
Do I need to open the speedo or is there an access hole for the pot?
TIA, Chris
Old 08-08-2002, 08:25 AM
Cool
Warren is correct...the last time I posted on this subject all hell broke loose and I was the devil..the routine feeling around here is to send out the speedo to a pro..............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-08-2002, 08:27 AM
Friend of Warren
Warren, don't leave us hanging here! I thought I needed to send my speedo off to be adjusted. Could you give us a step by step for adjusting the electronic speedos? Ron, I remember your prior post, but can't find it in a search.
Kurt V
Cool
Gentleman..this is what I did/non profesional/weekend wrench style
I pulled speedo
I removed screws from rear of speedo that holds a plastic mount for wires
I gently moved plastic wire mount so I can see inside
look inside using removed bulb sockets and thru hole under plastic wire mount
look for an itty bitty screw the size of eyeglasses hinge screw/or smaller..the screw is almost invisible in there
drill a hole on speedo case to be able to access itty bitty screw with itty bitty screw driver. use new drill bit and be gentle
a small adjustment of the screw will affect the speedo reading..lets say a move from the 1 o'clock position to 2 o'clock position may affect a 5mph difference in speedo reading..I believe clockwise increases the speedo reading..don't remember the exact direction..but I think I'm correct
the pros adjust for 30mph and 60mph, I believe
I would start adjusting for your routine speeding ticket areas against a newer car with cruse control on a flat straight road.
Some people have said that you can't adjust for high and low speeds by the itty bitty screw..that if you adjust for high speed your low speed will not be accurate. I believe I'm correct for high and low speed..not sure how finely tuned the speed is..will check it at next smog test..It's 10X better than before the surgery..and on big roads, such as flat Kansas, when you know that the mom and pop sedan is on cruse control at speed limit I'm accurate ...........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-08-2002, 10:24 AM
Friend of Warren
Ron, thanks! I'll try your method out. I have a very accurate portable GPS that I can take in the car to see if the changes reflect the correct speed.
Kurt V
Old 08-08-2002, 10:33 AM
CBRacerX's Avatar
I'm ready
to give this a try. I've got a spare speedo (with only 5K miles..) so I'll try it on that first.
Thanks!
Chris
Old 08-08-2002, 11:04 AM
Cool
Kurt..you will be actually be doing me a favor by adding credability to this speedo adjusting/weekend wrench style.......Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-08-2002, 11:25 AM
I am trying it too. I have nothing to lose since I am off so far with no apparent reason. All the "itty bitty's" make me nervous but oh well, it is only money if I screw it up, right?
Old 08-08-2002, 01:04 PM
Cool
Ted...I don't believe adjusting the trim pot affected the odometer setting..I tried testing on the "measured mile" on big roads and couldn't see any difference...and whoever succeeds at adjusting the speedo please post your results..........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-08-2002, 03:15 PM
I agree with Ron. My speedo is 9-10 mph off and the odometer was right on with mileage markers on the road over a 5 mile length. They don't seem to be connected, much to my relief since my 83 SC only had 78k when I purchased it a year and a half ago and I now drive it daily.
Old 08-08-2002, 03:23 PM
Cordts's Avatar
Can you adjust cable driven speedos on a early car..
1967S Porsche Targa #500317S EURO
1972 BMW 2002Tii
1967 Triumph TR4a Irs
1967 Austin Healey "Bugeye" Sprite
1966 Austin Healey 3000 MKIII
Old 02-12-2007, 12:37 PM
