86 ssinit's Avatar
What's missing??
Looking at an 83 sc. Looks like the fresh air blower has been removed. Is this common and what are the advantages or disadvantages? Also in the pics below what else is missing or added. Thanks all TOM
1986 Porsche 911 Targa
1983 911 sc
2015 WRX
Old 09-01-2013, 08:10 AM
schumicat's Avatar
it is removed when you backdate the heating. there are many threads on this. it cleans up the engine compartment. the blower helps move hot to vents at idle speeds. it also occasionally catches fire.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 09-01-2013, 08:30 AM
non-whiner
mreid's Avatar
You're also missing the cover for the rear fuse panel and you should source the left side block off plate so your cooling air doesn't bypass the engine.
"Too much is just enough."
Old 09-01-2013, 08:40 AM
non-whiner
mreid's Avatar
Doesn't look like you have hydraulic tensioners either...
Old 09-01-2013, 08:41 AM
ROW '78 911 Targa
timmy2's Avatar
The blower has been removed but the ducting to backdate has not been installed. The car will not have heat.
Old 09-01-2013, 08:51 AM
GaryR's Avatar
Send a message via ICQ to GaryR
Cap that left side duct, you are losing a LOT of cylinder cooling air out of there. They sell a block-off cover that eliminates the duct or you can cover it with metal tape or a plug.. as Tim said no heat.
Gary R.
Old 09-01-2013, 09:12 AM
86 ssinit's Avatar
Thanks for all the responses. I have not bought this car I am looking at it and noticed all the open space in the engine compartment and was wondering what was missing. Now if I install the ducting I will I have heat ? Also will this solve the cooling air problem? The car is from Florida and Georgia so I guess heat wasn't needed. Thanks again.
1983 911 sc
2015 WRX
Old 09-01-2013, 10:16 AM
86 ssinit's Avatar
Just asking again is it only the duct that needs to be replaced?
1983 911 sc
2015 WRX
Old 09-01-2013, 09:07 PM
This should help
Quick ‘n’ Dirty 911 SC Heater Backdate
Tks
Ed
Old 09-01-2013, 11:44 PM
ROW '78 911 Targa
timmy2's Avatar
Many threads on heater backdate here. The search button is your friend.
Pelican Parts Technical BBS - Search Results
I'm sure you read most of them in the 10 or so hours between your posts...
Old 09-02-2013, 01:37 AM
Senior Advisor
James Brown's Avatar
good news, still have cruse control
08 Cayenne Turbo
Old 09-02-2013, 01:46 AM
S2GART's Avatar
You will need the duct that goes to the blower motor which you will also need. Then you will need the 2 hoses that goes to each heat exchangers.
The "collection"
1983 911 SC Targa (1 of 1430 imported)
1994 MB E320 Coupe (1 of 825 imported)
1992 MB 190E 2.6
2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
Old 09-02-2013, 10:23 AM
Banned
If it has heat exchangers. The exhaust may of been replaced without them, it is an option.
Look underneath and make sure it has them, if you want heat in the future.
Old 09-02-2013, 12:07 PM
86 ssinit's Avatar
No heat exchangers headers I guess that means no heat? I read the quick and dirty thread thought that would be any easy fix but now that I see it has headers is there a way to still get heat?
Old 09-02-2013, 04:00 PM
schumicat's Avatar
not really. you could get a webasto gas heater but those are rare and probably dangerous. or sell the headers and get heat exchangers, someone would probably trade you.
Old 09-02-2013, 04:41 PM
