What's missing??
Looking at an 83 sc. Looks like the fresh air blower has been removed. Is this common and what are the advantages or disadvantages? Also in the pics below what else is missing or added. Thanks all TOM
1986 Porsche 911 Targa 1983 911 sc 2015 WRX |
it is removed when you backdate the heating. there are many threads on this. it cleans up the engine compartment. the blower helps move hot to vents at idle speeds. it also occasionally catches fire.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
non-whiner
You're also missing the cover for the rear fuse panel and you should source the left side block off plate so your cooling air doesn't bypass the engine.
"Too much is just enough." |
non-whiner
Doesn't look like you have hydraulic tensioners either...
ROW '78 911 Targa
The blower has been removed but the ducting to backdate has not been installed. The car will not have heat.
Cap that left side duct, you are losing a LOT of cylinder cooling air out of there. They sell a block-off cover that eliminates the duct or you can cover it with metal tape or a plug.. as Tim said no heat.
Gary R. |
Thanks for all the responses. I have not bought this car I am looking at it and noticed all the open space in the engine compartment and was wondering what was missing. Now if I install the ducting I will I have heat ? Also will this solve the cooling air problem? The car is from Florida and Georgia so I guess heat wasn't needed. Thanks again.
Just asking again is it only the duct that needs to be replaced?
ROW '78 911 Targa
Many threads on heater backdate here. The search button is your friend.
![]() Pelican Parts Technical BBS - Search Results I'm sure you read most of them in the 10 or so hours between your posts...
Senior Advisor
good news, still have cruse control
08 Cayenne Turbo |
You will need the duct that goes to the blower motor which you will also need. Then you will need the 2 hoses that goes to each heat exchangers.
The "collection" 1983 911 SC Targa (1 of 1430 imported) 1994 MB E320 Coupe (1 of 825 imported) 1992 MB 190E 2.6 2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
Banned
Look underneath and make sure it has them, if you want heat in the future. |
No heat exchangers headers I guess that means no heat? I read the quick and dirty thread thought that would be any easy fix but now that I see it has headers is there a way to still get heat?
not really. you could get a webasto gas heater but those are rare and probably dangerous. or sell the headers and get heat exchangers, someone would probably trade you.
