dazed and confused
john baldwin's Avatar
3.2 Alternator harness attach
Hi all,
3.2...putting the alternator harness back on I discovered I didn't have the screws that fastened these cables to the shroud. Don't know what happened on disassembly....thought I'd put everything back in that bag...
Worried that sheet metal screws will vibrate off...thinking of going with Omega clips...thoughts?
...or maybe there were Omega clips there when I took it off and they disintegrated when I removed the harness? Can't recall and pics got lost....
Thanks in advance
John
89 Carrera 3.2 Targa
2011 BMW 335d
2013 BMW X3 3.5
80 911 SC Weissach Coupe (Sold)
Old 09-07-2013, 05:58 AM
there are no screws holding the harness to the shroud. At best, they are attached via a plastic ring that rings around the harness and small foot that snaps into the hole. they don't work that well.
The metal loops you show are attached around the cable harness and then fastened to the intake runners with a M6 bolt/washer.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-07-2013, 08:18 PM
ROW '78 911 Targa
timmy2's Avatar
Plastic push in omega shaped clips are what you want.
Old 09-07-2013, 08:34 PM
dazed and confused
Clips
yelcab1
Thanks, I didn't take pictures as I was taking this apart...that helps alot.
timmy2,
I've got the clips on order...should be here Monday. I'll probably attach the cables with a combination of both.
Last details before it all goes back in!
j
2011 BMW 335d
2013 BMW X3 3.5
Old 09-08-2013, 04:52 PM
