nicfranc's Avatar
CIS Removal broken pipe discovery
While I was removing the CIS to get to the Triangle of Death I discovered the aluminum pipe that runs under and behind the air box was broken at the junction.
Any suggestions on a repair or work around ?
I can't get a hose & clamps in there for a splice because of where the break is located.
1980 911sc Petrol Blue Metallic Targa, 300,000 + miles
M&K Pre Muffler + M&K 1 in & 1 out Sport Muffler
Previously owned and rebuilt:
60's VW Bugs, Buses & Ghias
Old 09-09-2013, 04:54 PM
KNS KNS is offline
Would a broad muffler clamp hold it together? Or perhaps some very thin sheet metal wrapped around and held with two clamps (hose/fuel line clamps).
Kurt
Old 09-09-2013, 05:09 PM
Replacement is best option but I dont think you ll do it in the car. I have an 80 injection system on the table so the part is available and can look to see if its doable in the car.
Bruce
Old 09-09-2013, 05:11 PM
You might be able to do it in the car, there is 4 clamps holding it in. The most difficult would be the clamp by the 7th injector. cold start injector. 1 on the back of each diaphram and one over #5 intake.
Bruce
Old 09-09-2013, 05:20 PM
pete3799's Avatar
If the motor is out.....remove and replace or have it welded.
Pete
79 911SC RoW
Old 09-09-2013, 05:22 PM
nicfranc's Avatar
CIS is being removed with engine in car
I have done a partial drop and removed all the manifold runners.
I am removing the CIS and making all the usual repairs.
I guess I will be needing a new pipe.
Unless………Can i strip down the CIS and run it without the AAR and Decel Valve ?
Is there a way to run a stripped down version of the CIS without all the plumbing ?
I do not have to pass omissions.
I know….. I am going straight to Hell... but hopefully I will be going in an Old Porsche ;-)
Old 09-09-2013, 05:36 PM
nicfranc's Avatar
CIS Patient Opened Up and is on Table
Can I get the pipe welded do a partial reassembly of the Air Box components outside the car and then reinstall the rest in the car ?
Obviously flying by the seat of my pants here.
Old 09-09-2013, 05:46 PM
lonewolf's Avatar
Get a new pipe,
weld it
or cheaper but will work JB weld.
Old 09-09-2013, 05:48 PM
nicfranc's Avatar
Originally Posted by lonewolf View Post
Get a new pipe,
weld it
JB Weld…. very Macgiver Like…….That I have on hand.
Maybe graft in a piece of aluminum tubing…like a shunt or stent.
This could work.
It is not like I a moving fuel here, it is just air.
I believe the part is number 46.
I looked around for this part for my 1980sc with no luck.
Old 09-09-2013, 06:12 PM
nicfranc's Avatar
Ouch…CIS Air pipe $$$
$550 !!!
Part number 911 110 277 01
I guess I can just make it out of copper tubing.
Old 09-09-2013, 06:23 PM
nicfranc's Avatar
Area of break
THIS IS NOT MY ENGINE BUT YOU CAN SEE WHERE THE BREAK IS.
Old 09-09-2013, 06:49 PM
nicfranc's Avatar
Aluminum air pipe
PART NUMBER: 911-110-277-01
Anyone have one ?
Old 09-09-2013, 09:00 PM
Slippery Slope Expert
Steam Driver's Avatar
I might have one (maybe even two!) of those but I'll have to check tonight and let you know. Are '78 - 79 and '80 up the same? I may have one of each!
Old 09-10-2013, 03:44 AM
kodioneill's Avatar
I cant believe the car ran with a huge vacuum leak like that?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 09-10-2013, 03:51 AM
also curious about what caused it to break? bad motor mounts? Other?
HB Kramer
(4 sneaks and 6 airheads): 79 911SC Coupe (sunroof delete)
(2 sneaks and 2 airheads): BMWS: R12GS(a) R90S, and some old British iron as well.
Old 09-10-2013, 04:23 AM
nicfranc's Avatar
Aluminum Air Pipe to AAR, AAV, DeCel Valves
Those were my thoughts as well.
It did not start well but it did run fine once warmed up.
I have read where holes or cracks have been created in this pipe
due to vibration.
I did notice looking through my old photos that the rubber support by the number six runner was not connected.
Perhaps this was the cause of the break.
Old 09-10-2013, 04:26 AM
nicfranc's Avatar
Cause of Pipe break
From the photos i took before disassembly it looks like the bracket was not reconnected
to the rubber mount in front of number six runner. Either that or it came loose some how over the years from vibration.
Old 09-10-2013, 04:33 AM
nicfranc's Avatar
Aluminum Air Pipe
I am not sure if they are all the same.
I will do some more research.
Old 09-10-2013, 05:01 AM
I went and looked at the pipe on the '82 system I have. It is totally screwed up and not usable. (Well, maybe you could in a "cut and weld" sort of fashion) The P/O's mechanic (or someone) pinched the pipe in two places, obviously to shut off it's function from the decel valve and AAR. I'm pretty sure this was done on purpose, I doubt it could have happened in shipping. (I suppose I should give them the benefit of the doubt, but . . .)
So it's essentially history. That's the "loose" system I have stored here at work. When I'll get home this afternoon I will check the one on the pre-'80 system that's currently installed on my engine and let you know. I'm not going to reinstall the CIS, so everything I have is essentially surplus.
Old 09-10-2013, 05:19 AM
nicfranc's Avatar
So it's essentially history. That's the "loose" system I have stored here at work. When I'll get home this afternoon I will check the one on the pre-'80 system that's currently installed on my engine and let you know. I'm not going to reinstall the CIS, so everything I have is essentially surplus.[/QUOTE]
Thank You.
Old 09-10-2013, 05:42 AM
