na2ub's Avatar
I am not installing a thermostat. Do you know the correct pitch / thread I need for a bolt to plug the thermostat hole?
This post was auto-generated based upon a question asked on our tech article page here:
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 09-17-2013, 03:05 AM
Nick at Pelican Parts's Avatar
Not off the top of my head. Personally I would use a thread gauge to measure it.
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
KTL KTL is offline
Schleprock
KTL's Avatar
The t-stat in the engine is a huge hole.........
But if you're not running a t-stat, you can simply gut the t-stat by popping the cap off the bottom and remove the regulator.
Note that you'll have oil going to the small oil cooler right away when engine is cold. That's not good for the cooler, as sometimes can rupture due to difficulty of cold oil to flow thru small passages in cooler.
If you're removing the cooler and installing a filter housing, then oil cooler is a non-issue. However, it'd be wise to plug the cold side of the t-stat. Because w/out the t-stat in place, you have oil flowing in the cold direction and also the hot direction (thru the filter on hot side)
Here's some background on the cold vs. hot routing
Sanity Check- Oil Routing w/out Engine Oil Cooler
Kevin L
'86 Carrera "Larry"
Old 09-17-2013, 03:52 AM
Are you sure you mean the thermostat? - there is no thread, it's just a smooth bore hole.
Kinsley
1980 SC Targa - MS2, EDIS
Old 09-17-2013, 05:16 AM
Post a picture..........
Could you kindly post a picture of this 'hole'? Thanks.
Tony
Old 09-17-2013, 06:17 AM
docrodg's Avatar
Which thermostat? Engine or external oil cooler?
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 09-17-2013, 06:18 AM
Fleabit peanut monkey
Bob Kontak's Avatar
M6 X 12 per the PET
Just find a bolt in your stash for the pitch. It's a standard pitch. I don't remember it being a fine thread. Alternatively, take the nut to Lowe's, Home Depot or the local parts store and they (usually) have one of those gauge thingies you can screw nuts onto or screw bolts into to determine.
You are talking about a replacement cap, surely?
1981 911SC Targa
Old 09-17-2013, 06:25 AM
RETIRED
Joe Bob's Avatar
If the bung is in the cooler......just use a sender and not connect it. Make sure it is flush and secure. Nice oil leak point.....
2012 ML350 3.0 Turbo Diesel
Old 09-17-2013, 07:40 AM
