Schleprock
The middle t-shaped pieces will slip thru. It's the end pieces that have the punched area the holder spring things hook into. You know, the punched area that rips open with age and the tin doesn't stay in place tightly
Kevin L '86 Carrera "Larry" |
Always Be Fixing Cars
Guys I'm really frustrated with this damn 90deg hose. My hydraulic hose shop doesn't have the 5/16" heavy wall hose they thought they could get.
Smoove said he managed to avoid kinking the hose by sheathing it in some SS braided material he had left over. Wondering if something like this would do the trick? Goodridge Goodridge Universal Braided Steel Oil/Fuel Hose - JCWhitney Also wondering why that line had to be soft in the first place. Why on earth isn't it a hard line? There is no flex in that connection so far as I can tell.
'91 964 C4 - New Daily '73 Alfa GTV - 90% done 50% to go '65 912 - Welding in process |
Forgot my camera for the most fun part of assembly! Some pictures from my antique phone...
Boy things go much faster when the parts are all clean. I used loctite copper antiseize on the headstuds & nuts and torqued them in two steps per Bentely and Wayne's book. Noticed that 23.5 ft-lbs (wayne) is slightly less than an extra 90 degrees (bentley) by my torque wrench. Drawing gaskets with Loctite 574. Philosophical question: why did porsche not use a solid gasket in this location? ![]() Looking suspiciously like a 911 longblock... Oil return tubes are collapsable type and will be installed after the cam carriers when I get the correct seals later this week. That is pretty easy to do, right?
Registered Loser
Damn, you are taking the lead ahead of me big time!! Nice work!!
Current Rides:: 1987 Red 911 Targa, 2007 R320 CDI, 2003 Red Dodge Ram Hemi, 1993 Beater Jeep Cherokee, Airbus A320 Gone but not forgotten: 1981 VW Scirocco S, 1989 Honda Accord Coupe LXI, F-16C (still my favorite vehicle!),MC-130P, C-130E, T-38, T-37, C150, C172, PA180 |
Schleprock
On the next cam housing, use a LOT less sealant. Brush it on thin and uniformly.
Also, no reason to run the sealant across the middle area. There's no oil to seal in that area. Only need to seal around the valve spring openings and those four bolt holes surrounding each opening. When you tighten up the cam housing to the heads, you'll see a lot of excess sealant squeeze out. That's a gauge of how much sealant is needed, which is not much at all. Just a thin skim coat. Henry @ Supertec makes some spacers/gaskets for the cam housings. They're used for adjusting the alignment of the cam housing, head, cylinder "stack" when the parts have been machined for various reasons
Kevin I was following this video: Nick Fulljames fits cam housing & talks ramps.wmv - YouTube
He mentions running a bead 1-1.5mm tall. I was going to clean up the squeeze-out today.
Schleprock
I don't like a lot of the things that guy says.
That amount of sealant is just too much. If you get a big amount of squeeze out, then that says to me a lot of sealant was wasted. Instead, brush it on uniformly to get just a tiny bit of squeeze out. This stuff does not brush on super thin, so there's no worry of not using enough. His perspective on RSR seals for the rockers not working is sorta silly. His caps with o-rings are really no different than the RSR seals. Both are a light interference fit in the rocker shaft bore. The only thing his caps provide is a means for sealing the end and keeps dirt out of the bore. So when you remove the caps, the bore is clean and shaft removal won't scratch the bore. But the rocker shaft sealing isn't a huge epidemic problem. Tightening them sufficiently will arrest walking shafts and most leakage. If not, big deal. Get a good set of used cam housings. These things are incredibly cheap when bought used and are not hard to find. Recyclers like DC Automotive, Parts Heaven, etc. have piles of these things on their shelves.
Fair enough re sealant. I do think Nick's seals are an improvement on RSR style for the reason he mentions - his design lets the shaft install easily and then it actually expands the seal. However I think he sees the need for the seals for older cars that may have suffered long sitting and or many rebuilds over the years. For a 3.2 like mine the plan is to install the rockers per your link, dry, higher torque than the "new" spec.
I did not like his suggestion of 574 on the OR tubes - my understanding is that they're supposed to slide back and forth in their bores and loctite would prevent that once cured. BTW someone confirm I'm not stupid - its easy to install the 2 part tubes even with the cam carrier in place, right?
Schleprock
574 is a hardening sealant. There is no reason to use that on the oil return tubes. That's an improper application of the stuff. It's a flange sealant for flat mating surfaces with or without gaskets. O-rings for the return bores need to have some room to move around.
Yep it's easy to install the tubes with the cam housing in place. But it's not a walk in the park. New o-rings, even when lubed are stubborn to allow the tubes to expand. You need to leverage them to expand. Common trick is to use some typical hose clamps on each tube piece, with the screw body part of the clamps aligned with each other. Then use a tool of some sort to lean on the screw bodies to move the tubes apart. Do a search for the various tools people have cooked up for this.
I have the case sides of the OR tubes installed, using the green o-rings provided in my Wrightwood racing kit. Went in pretty easy. Also just want to check that there is only one style of OUTER o-ring and they suit factory one piece, two piece and billet two piece OR tubes? I ask because it looked like the o-ring I removed from my billet two piece OR tubes, which was red, was squared off. I presume this is just from age and compression/heat cycling...
83 911 Production Cab #10
That was for removal. To install, on clip on each half and spread them out with a flat bar between the bandit screw.
![]() More removal pics @ Oil Tubes Removing and Refurbishing
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Got both cam carriers and cams installed. I test fitted the left side cam dry, but with the cam housing fully torqued down. It spun very freely, as in just a few fingers worth of torque. When I went back and assembled everything "wet" with 574 on the mating srfs and assembly lube on all cam bearing srfs & lobes, it was a good deal harder to spin. I'm putting this up to the assembly lube closing up tolerences. There were no tight spots around, but it did take a fist around the camshaft and an tacky glove to rotate it. Sound kosher?
![]() Cams were in great shape, no pitting anywhere to be seen ![]() Almost a sin to cover them up ![]() Both carriers on ![]() Then it got slightly tricky. The R chain housing was not sitting right with regards to the cam carrier. After some fiddling I realized that I was overzealous with the JB weld and it was causing the carrier to push rearward. Sanded it down and all was well. ![]() Then, one of the M8 nuts on the chain carrier stripped while being torqued down! I'm surprised since these nuts lived a leisurely oil bathed life. Really not sure what lead to this. Luckily I have a big old sack of yellow chromate M8s arriving tomorrow. ![]() Got the paper gasket, green o-ring (both lightly curil-t'd) and cover plate installed. Ran out of time for the night but really wondering how on earth its possible to install the chain around the cam sprocket at this point. Also - any tips on woodruff key install? Gave it a quick go before retiring for the night and it did not seem fun. Getting them out was hard and destructive. I have two new ones.
Straight shooter
Here's how I handle the key install:
![]() Don't forget the shims first.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Registered Loser
Russ,
Did you replace all six chain ramps?
Lapkritis - thanks will give it a shot. Happen to recall the ID of the pipe? edit - i see the pipe goes OVER the woodruff key. Okay so its really just a matter of protecting the jaws of some sort of pliers. Will give it a shot.
Mike - nope, just the two in the outer chain housings. I messed them both up getting them off. Found that heat really helps with install/removal. Pretty sure its next to impossible to replace the others without splitting the case, which mercifully I am not.
Sugar Scoops Rule :)
This is a great thread. I just spent the last few hours (at work....shhh
...!) going through it.I'm sure my never-been-rebuilt 2.7 is going to need this (and more probably) at some point. I've owned it and driven it for 27.5 years and counting. thanks for the outstanding play by play.
Dave _______________________________________________ '76 911S Targa '62 VW Type 1 Sunroof '73 914 2.0 (1st Porsche, gone long ago but not forgotton) |
Glad you like it. I appreciate everyone who reads and comments. And I love that you have been driving a never rebuilt 2.7 for 27 years! If we believed the internet, every 2.7 will overheat while simultaneously pulling studs and eating valve guides. You must have one of the good ones. Keep driving!!
Straight shooter
1/2" PVC pipe from Home Depot. Used it in many places during the build... such as holding the cylinders on before the heads,insulating while moving stubborn rocker shafts, getting the tensioner bits over the pivot posts etc...
Smoove1010
I found the inners were easier to remove than the outers. As I loosened the bolts that hold them in place, the machined ends that attach to the ramps tended to ease out of the plastic clips/tabs. The outers needed prying, which tended to break the tabs - one more thing to worry about falling into the case... The inners on mine showed wear - my chains looked more worn than yours as well. I was more concerned about these plastic parts being embrittled over time and heat cycles than wear though.
Schleprock
I think you're OK with the cam as you described it's rotation. The assembly lube is some pretty thick stuff. That said, use it really sparingly. You don't want it to build up around the cam bearing oiling bores. I suspect when oil pressure is generated at initial startup (ignition & fuel disabled, crank engine over w/starter until you see oil pressure gauge needle start to show pressure/flickering) the oil will push thru the assembly lube.
The sprockets are a bit tough to get in place with the chain box on. You can do it though. Just have to fiddle with the positioning of the chain rollers on the sprocket teeth. When you do the left box, put the sprocket on the chain at the same time you are setting the box in place. Double check that chain box stud where the nut stripped and make sure the stud isn't spinning in the case, or that the stud itself stripped. That's a neat trick to install the woodruff keys Andrew! I typically use a tiny hammer with light tapping on the key to set it down in the groove. Have to tap it down and play with its position to get it level so it'll accept the keyed hub that you slip onto the cam snout. You'll find that you have to play with the key a little bit because as you push/tap the hub onto the snout, it sometimes pushes the key out. So you have to make sure the leading end of the key is a teensy bit lower than the groove in the hub so that it pushes the key down and holds it in place vs. pushing it up & out of the groove. YOu'll see what I mean when you start playing with it. Shove a paper towel(s) in the case opening so a key that pushes itself out doesn't tumble down into the case....... The inner chain ramps can be a bit of a pain to fiddle with but they can be replaced with the case assembled. You just have to make sure the ramp seats onto the special bolt properly. Its sort of easy to get them on only 1/2 way. Easy way to remove them w/out dropping into the case is to clamp a pair of needle nose vise grips on the end of the ramp as you're loosening the bolts. Bolts "press" themselves out of the ramps via the bolt threads. Reinstallation requires a bit of patience to get the ramp pressed into the nubs on the bolts. Really not that hard though. I'd use some silicone paste or just plain oil on the cam plate o-ring. Lets it move freely vs. the stickiness of the Curil. The Curil T is OK for the paper gasket but it's stickiness can also displace the gasket as you're pushing the cover plate home. 574 is better to use on the paper gasket since it's not sticky. Be sure to take a close look at the gasket now that the chain box is in place and look to see if it stayed aligned with the cam housing bore. If it moved and you can see an exposed amount of paper edge hanging off, re-do the gasket install. Andrew can attest to this, as he discovered it during his reassembly. That leak is a sucky one to fix after the fact. You don't want that sucker to leak because you're pretty much guaranteed to pull the engine back out. Since you have to get the sprocket off, which means re-timing the cam, to get at that gasket? Cam timing isn't easy to do with the engine in the car. Too much hassle with trying to tighten the cam bolt, setting up the dial indicator, turning the engine over, etc. Best to take the engine out. Obviously you want to avoid the engine coming back out after all the work you put into it, just for a pesky leak. That leak is a steady one since the cam cover plate sees actual oil pressure, not just splash oil, due to it being right next to the cam bearing bore that is under pressure from the spraybar.
