Idle on 70T has a mind of it's own...Help
Greetings Pelicans
My T's idle with stock Zeniths is driving me NUCKING FUTS!!!!!!!!!!! I'll get it warmed up and do the textbook settings as far as ignition and carbs and it'll be idling at around 800 rpm.......I'll blip the throttle and it will come back to 800 and all is good. Then I'll go out and drive it and occasionally it will stay at 2000 or climb to 2000 and stay there. I have to drag the clutch sometimes to get it to come back to 800 The linkage seems fine and isn't sticking.................what gives? Dirty Marty Fallbrook Ca
dirty distributor advance mechanism?
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Something is binding. Years ago running webers I had the same problem. Turned out to be a sticking throttle butterfly. An ever so slight adjustment using the attaching screws made it all good. Then I put on PMO carbs and all is smooth, smooth, smooth. Love em.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
