Je Ne Sais Quoi = Targa
Mikey83835's Avatar
Head Stud problems in a 964 3.6?
I am on the verge of buying a 92 3.6 motor for my lightweight outlaw-type '74 Targa, motor has all the rebuild receipts from 2005 and seems to have logged 14k miles since then, had 128k at rebuild,
All the right stuff including the new style cvlinders/pistons, but the head studs were not replaced, this seems to be a huge concern for the 3.0 motors, and the 3.2 motors to a lesser extent, they are not usually replaced at rebuild on a 3.6?
Motor is out of car so PPI might be difficult, but leakdown numbers look good,
Opinions?
'74 Targa lightweight widebody, 3.6 motor, big bars, Speedlines, Sold 2018,
'81 SC Targa with 3.2 spoilers, Webers, SSIs, 7&8X16 Fuchs, 911R style exhaust,
Had a '71 911S Targa in the 80's, miss it,
Had a '61 Roadster in the 70's, miss it also,
Old 09-29-2013, 01:02 PM
Mikey83835's Avatar
No opinions?
Old 09-30-2013, 08:34 PM
safe's Avatar
Usually the studs are OK, those engines (3.6s) I have come across has had all steel studs, not the dilavar crap.
On the other hand I have fitted Supertec studs to a 993 3.6 and a 964 3.6 because there was envidence of leakage and movement between the cylinder and heads.
Magnus
Old 10-01-2013, 03:48 AM
A 92 964 will have dilavar studs top and bottom. They will occasionally break
though not with the frequency of 3.0-3.2 motors. Do a leakdown test if you're concerned
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 10-01-2013, 03:53 AM
Discovered one bad one on my car when I first got it (~112k). Running one short, just crossed 140k.
'90C4
Old 10-01-2013, 07:11 AM
They do break.
Problem is corrosion of studs themselves- internally, that snaps the ends off with bolts intact.
I have a 1991 964, 186,000 miles and just found three stud ends with bolts attached in the valve covers when preparing to do a valve adjustment.
911S/GTS4
964 C4
1987 Carrera 3.2
Old 10-01-2013, 07:41 AM
safe's Avatar
Originally Posted by umgang View Post
They do break.
Dilavar?
Strange, possible that there is a difference between US and ROW cars on this. I have checked 4 964 engines and 1 993, they all had just steel studs.
Magnus
Old 10-01-2013, 08:11 AM
You must have jinxed me 2 customer cars today with broken studs 1 intake 1 exh
993 were steel
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 10-01-2013, 10:22 AM
Originally Posted by safe View Post
Dilavar?
Yes, Dilavar. The problem is not like the old days where they pull out of the case.
The problem here is simply age and corrosion. They corrode and snap, in my case with the head stud bolts still in place.
911S/GTS4
964 C4
1987 Carrera 3.2
Old 10-02-2013, 07:07 AM
