It didn't fall 'IN' the motor after all...
but the motor wouldn't rotate by hand more than about 300 degrees...
Documented here: I hope this isn't a 'Newbie Screwup' so I decided to drop the motor and find the problem. Now my motor looks like this: ![]() and this is what I found that somehow was keeping the engine from rotating. ![]() So, not inside the motor after all... Now what to do... A bit of background: Bought the 1978sc with 193,000 miles in August '13 for $8k because it would not pass Calif smog test. The car had sat mostly undriven for the last 12 years snug in a garage . I was sure I could solve the smog test problem with a freshening of the CIS system. No history on the vehicle Heads look clean inside, engine crusty outside The PPI showed the following (pressure test, leak down): Cyl 1: 150psi, 8% loss #2: 155psi, 5% loss #3: 155, 7% #4: 130, 25% loss, blowby past ex valve seat #5: 150, 25% loss, blowby past rings #6: 145, 5% loss NO broken headstuds, at least none discovered yet... Clearly the engine needs lots of degreasing, but Not much money available at this moment for a 'full rebuild' I have replaced all the seals etc on the list of common leaks, replacing clutch with new kit. Want to get the car on the road and PASS SMOG ASAP. so I am looking for advice on what to consider 'Essential' to do but also very "budget conscious' Last edited by bryant4; 10-25-2013 at 07:09 PM.. |
chains closeups
With those leak numbers I would do a valve job. Send the heads to Anchor Atlantic and be done with it. Have had excellent results with them. I would also be inclined to replace the head studs while youre that far into it. Also I can't tell how much stretch those chains have, but I would inspect closely the timing chains and tensioners.
I am not sure I would do a valve job yet on that engine. Clean it up, fix the leaks, tune it up, drive it hard for a month, and smog it.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
The car as purchased
good advice
I like your advice, yelcab1
It agrees with my wallet right now... But I am gonna have a look at #4 and 5 since I am so close... good chance it was just carbon, right? (ever hopeful...) smokintr6, I agree with you but I'm trying to find a way around it... |
Caveman Hammer Mechanic
Hey,
Those leakdown numbers aren't that bad, get it running and drive it for 10 hours or so with an aggressive detergent oil(Brad Penn) would be a good choice. Then recheck the leakdown. Rings gum up and dont seal well and valves get crud stuck on the seating surface. If it runs well, get a pre-test done and drive it. Plan for the top refresh at your own pace. Get a temp operating permit and get all the paperwork in order and drive it for a month or 2. CIS doesn't like to sit for extended periods, and that might be why it couldn't pass smog.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 10-24-2013 at 10:43 AM.. |
Coram Deo
Beautiful color. But I'm biased!
I'd take the drive it for a while option. How far you've come (pulling the engine) is not nearly as far as where you'd have to go (pull heads). If money is tight and there's a chance it'll get better on its own, roll the dice.
Dru 1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter • 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio • |
thats th abyss. i dropped a bolt in there last night. did not get it out yet. that place REALLY sucks
Okay, so I went a bit farther...
One weird thing:
the studs seem to have been replaced already.
All 24 are the same. ALL DILAVER? they are powdercoated black. they are NON-magnetic ![]()
It's not too much of a job to pull the valves out and check the seats, lap them in by hand and put it back together. I would bet that the engine has had a recent top end and you just have some carbon in the seats.
It looks like it was probably tuned rich and someone didn't know how to properly flog the machine.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
just dug out my valve spring compressor for tomorrow morning...
I have a 3 day weekend so I plan a lot of 911 time... Regarding lapping... I have lapped motorcycle valves 'in the day' but I didn't find much about lapping Porsche valves...? |
Same theory, use some grit, elbow grease and patience. Check often with blueing. If you have a way to apply vacuum you can check for a good seal when closed. I remember the shop where I built my motor had an attachment for an air compressor that was used specifically to check the valves to seat seal.
Sioux Style Vacuum Tester
Cheap version: Valve Seat Vacuum Tester Cheaper version: Vacuum Testers : Cyllinder Head Rebuilding : GOODSON
Real cheap seating test
Put the plugs back in, fill the combustion chamber with water, blow compressed air into the ports. If air bubbles into the combustion chamber, more lapping required. This is the first thing I do after removing the heads to see what condition the valves job is in.
Bob B Last edited by NICE 69 S; 10-28-2013 at 09:24 PM.. |
Less brakes, more gas!
Bob B: Nice! I'll have to remember that trick.
that mount where your bolt fell... it has a drain at the bottom that usually needs to be drilled out clean. Also, you might consider drilling an access hole through that mount so you can get a socket on the nut that is hidden. Makes it really easy to put it back on
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Decided to send out the heads...
I cleaned up one head and lapped the valves and that worked great. I did it Makita style...
but one exhaust stud broke off below grade and there is quite a bit of guide wear... visible wear, pitting on one valve stem etc. see pic... So off they go to Ollie's in LHC ![]() fancy valve lapping device ![]() broken stud ![]() note guide wear
