CIS airbox replacement... how long?
2 questions.
1. How long to replace a cis airbox
2. Engine in or out of the car. Which is easier and faster.
Old 11-13-2013, 08:51 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Don't pull the engine.
Time for a pro to replace or time for a DIY guy that has never done it before? Pro - guessing up to 4 hours. DIY, budget a full day assuming you have all the parts at your side.
1981 911SC Targa
Old 11-13-2013, 09:13 AM
The later the model CIS, the longer it takes.
Bruce
Old 11-13-2013, 01:58 PM
theiceman's Avatar
my 78 took me 90 minutes to drop the engine about 4 inches and remove the CIS , never done it before .. beginning to having it sitting on my bench ..
spend 2 or 3 days completely rebuilding CIS once i had the parts.
about 45 mins to put back in ..about an hour of tweaking and CO adj ..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 11-13-2013, 02:38 PM
Peter Zimmermann's Avatar
A '76 (based on your user name) has auto cold-start, so my shop, depending on what we knew about the car, used either a partial drop (no oil leaks + clutch history), or engine removal. You'll want throttle bell crank/console bushings, thermostat o-ring, and an oil pressure switch, injector sleeves + o-rings; in addition to all the airbox replacement parts. It's an all day job to do right and clean, even for a "pro." You should know how to check/adjust the sensor plate height, and when the car is back together, be prepared to have a CO% machine available for tuning. After all that, you should probably plan on measuring cold control pressure (gauges required). Big job.
Keep the Shiny Side UP!
Pete Z.
Old 11-13-2013, 05:00 PM
account for every nut and washer. check down all the ports and turn the engine over by hand before reinstalling to be sure nothing went in. 76 is pretty easy. a 3/8" drive swivel socket is handy for the manifold nuts. a 4-6" drop helps a lot. shop time about 4 hours.
206 637 4071
Old 11-13-2013, 05:02 PM
nicfranc's Avatar
Tools for CIS Removal....
Swivel Sockets in both 1/4" & 1/2" drive with assorted extensions are key to removing the nuts under the runners.
I also found that a ratcheting articulating box end also was handy.
On my 1980sc the nuts were 12mm.
I am not sure what size they are on your engine.
Watch those nuts and washers while you remove them.
You do not want to lose anything down the open ports.
Have a magnet handy.
I used a tip from another Pelican board member and made up masonite covers for the intakes using the gaskets as templates.
1980 911sc Petrol Blue Metallic Targa, 300,000 + miles
M&K Pre Muffler + M&K 1 in & 1 out Sport Muffler
Previously owned and rebuilt:
60's VW Bugs, Buses & Ghias
Old 11-13-2013, 05:22 PM
nicfranc's Avatar
Block off intake ports
Masonite block offs for intake ports prevents nuts and washers and debris from
falling in engine.
Old 11-13-2013, 05:30 PM
