stv951's Avatar
How to make more power out of a 911 T 2.0
Hello,
I am looking for upgrades on a 911T 2.0 engine that i am installing on a 914 GT replica.
Which way would you go ? Higher compression pistons ? Cams ? Valves ?
What carbs ? Ignition ?
I dont want a race engine, just a fast - very fast road and occasional track use. Must have carbs
Old 11-16-2013, 11:45 AM
Originally Posted by stv951 View Post
Hello,
After digesting all the suggestions for upgrading a T engine, you'll discover that the same money applied to a 3 liter or larger engine will provide better results.
Some drawbacks with the T engine:
Cyl. heads w/small valves and ports
Non-counterweighted crank
Potential issues with mag case (i.e. pulled head studs, no oil squirters, refurb crankcase to specs)
OTOH, you can reuse the Weber carbs after rejetting, larger venturis, port-match intake manifolds; sell the 911 heat exchangers.
Sherwood
Old 11-16-2013, 12:02 PM
AutoBahned
RWebb's Avatar
an engine is an air pump
to pump more air:
1. use a bigger pump
2. spin the pump faster
3. pressurize the pump
it will be costly to make your engine into an "S" version with carbs (which is close to the limit, barring 1,2,3 above) but that is where you're at
I like carbs (cuz I are a cave man) but you're giving up 5 or 10 hp over MFI or performance EFI
You could always spend huge $$ rigging up a DI version of the 2.2
Old 11-16-2013, 12:06 PM
stv951's Avatar
I understand about the air pump theory. I need to use the 2.0 T as a base
What does it ake to make an S engine ? I would like to have around 170 PS.
I now have Zenith carbs not Webers. What PMOs do you wuggest or else ?
What about cams ?
Old 11-16-2013, 12:29 PM
Alter Ego Racing
ErVikingo's Avatar
If interested, i have 906 cams, cyls and pistons, webers etc for sale. Pm me if interested.
International GT Champion; Porsche GT3 Cup Trophy Champion; Klub Sport Challenge Champion; Rolex Vintage Endurance Series Champion; PCA Club Racing Champion; National Vintage Racing Champion
Old 11-16-2013, 12:48 PM
AutoBahned
RWebb's Avatar
is this for a class racer?
you'll want a balanced crank - maybe; there are some wt. adv.s to the T crank
blueprint it real well, including the oil pump
different heads
and you can get better grinds than an S cam these days (due to modern computer aided design, etc.)
you will match the PMOs to the cam
to save $$, buy that 906 above & hotrod the Zeniths
Old 11-16-2013, 03:28 PM
tharbert's Avatar
...you'll want a balanced crank...
Don't some of the racer types covet these non-counter balanced cranks because they spin up faster?
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 11-16-2013, 03:38 PM
copbait73's Avatar
Add a turbocharger.
Best, least expensive route to the most power out of a stock longblock.
Old 11-16-2013, 04:24 PM
Alter Ego Racing
ErVikingo's Avatar
You actually want a counterweighted crank which you lighten and knife edge.
An issue with a T motor is that the cylinders are iron and do not shed heat like the byrals which are iron liners with aluminum fins.
The largest valves on 2 liter motors were in the 69 911S but they are rare and pricey. I cannot use newer ones due to racing regulations but i believe you could use 2.2 heads which are less expensive.
I suggest you replace the oil pump for a newer large capacity one.
Old 11-16-2013, 10:33 PM
