GaryR's Avatar
Send a message via ICQ to GaryR
Picked up my case, polished crank, resided rods, etc. from the machine shop yesterday. Put the case 1/2 up on the stand and noticed this little imperfection -
Asked on the rebuilding forum, but would you put a little JB Weld over it or just leave it be? They blessed me by removing my timing and dizzy drive gears so i'm off to buy a pan to heat oil in to reinstall them...
Gary R.
Old 03-16-2014, 08:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
E Sully's Avatar
Skip it inside the case. Exterior is where it is where the Tech Bulletin recommends sealant. If the JB Weld came loose inside the case, bad things can happen.
Ed
1973.5 T
Old 03-16-2014, 08:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
GaryR's Avatar
That was my thought also, only caveat is if the areas spreads and more tiny aluminum chips are floating around...
Gary R.
Old 03-16-2014, 08:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
GaryR's Avatar
Yesterday... now she will go together quick..
Gary R.
Old 03-23-2014, 07:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
KTL KTL is online now
Schleprock
KTL's Avatar
Did you remember to calibrate the flux capacitor before gluing the case together?
Nice job dude. Looking good!!!
Kevin L
'86 Carrera "Larry"
Old 03-23-2014, 07:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
GaryR's Avatar
1.7 gigawatts exactly..
Gary R.
Old 03-23-2014, 07:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
Schleprock
KTL's Avatar
Oh man, you over torqued it..............
https://www.youtube.com/watch?v=I5cYgRnfFDA
Considering you over-gigawatted it, when that engine hits 88 mph you're REALLY gonna see some srs shyt
Kevin L
'86 Carrera "Larry"
Old 03-23-2014, 07:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
GaryR's Avatar
Finally, engine done, joined with re-geared tranny...
And in the car!
Do I need this thing plugged in?
Gary R.
Old 03-30-2014, 04:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
GaryR's Avatar
And where do ya get nuts for the coil terminals?
Gary R.
Old 03-30-2014, 05:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
michael lang's Avatar
Gary, thanks for putting your build up on the board. I've learned a lot from your sharing and plan on putting a lot of what you did into my build as my motor is on the stand right now waiting for me to tear into it.
Mike
'89 CARRERA
#402
Old 03-31-2014, 05:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
GaryR's Avatar
You are welcome!
Gary R.
Old 03-31-2014, 07:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
Schleprock
KTL's Avatar
Gary,
I believe that silver box is the relay for the rear window defroster since it has such a high current draw. If you still want to have 12V back there for some other use, you can leave it in place to avoid having to bypass/rewire. Or else remove it and put the 12V feeding the relay somewhere that you can connect to it later on. Good to have 12V available back there for timing light, remote starter, etc. Could also use that high current circuit for a trans cooler pump?
Coil nuts are nothing special. Parts diagram shows basic washer, lock washer and plain nuts. Nuts are either M5x0.8 or M6x1.0. I'd personally use a flanged lock nut to of course avoid loosening and also eliminate the needless extra washers.
Kevin L
'86 Carrera "Larry"
Old 04-01-2014, 07:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
GaryR's Avatar
Originally Posted by KTL View Post
Gary,
Thanks Kevin, I was going to take the 3-fuse box, convert to spade type, and mount it over on the coil backing plate to have power back there. I'll just tape up the plug for the relay for now..
Gary R.
Old 04-01-2014, 10:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
jm993rs's Avatar
Good post !!
Thank you .....
Old 04-01-2014, 01:18 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
GaryR's Avatar
Well, tonight was the final wiring connection. Got everything set, unplugged coil and injectors and hit the key.... it cranked over and built oil pressure. All the oil seems to still be in the motor so I connected everything and cranked. Fuel pump made a strange multipitched whine when running but no fuel on the rails.. and no spark. Tried flipping the two hall sensors and still nothing.. Guessing the fuel pump died over he winter but very odd as it just sat for a few months in my garage with treated fuel in it. The spark has me stymied, only so many wires to hook up!
Gary R.
Old 04-03-2014, 06:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
GaryR's Avatar
Well, the issue is resolved , thanks to my buddy Bela, and she's alive! Fuel problem was feed/return lines were swapped at the tunnel, the spark problem was the circuits I chose for a couple of the power feeds dropped power during cranking! Engine sounds great, oil pressure seems a bit off (high), could be the wiring on the sender but i'll figure it out tomorrow when I button everything up and get her ready for the track on Tuesday for a shakedown run...
Gary R.
Old 04-05-2014, 03:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
