How to remove rear view mirror mount button?
I am a very tall driver and the stock single joint adjustment mirror sits too low. I want to replace it with a double jointed mirror that can be positioned higher in my line of sight.
Question is, does anyone have suggestions for removing the stock mounting button without cracking the windshield? Thanks. |
it's always a bit chancy, but glass shops use heat, just enough to soften the cement, like from a tiny butane torch. we're talking the small, round metal tab, not the big black square thing. i've used a piece of metal with a hole cut just the right size so it slips over the tab, to keep the heat off the glass, then a slight twist with pliers gets it off when it's ready. the original cement is clear. JB weld or some other stuff may not respond to heat as well.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 08-26-2002 at 02:38 PM.. |
When I replaced my windshield I attempted to remove that button. It was stuck fast and not meant to be removed. Maybe someone on the board will know of a trick.
Walt 82SC 3.0 81SC 3.6 |
After you move the mirror up higher, how do you get rid of the old cement stuck on the window from the previous mirror position?
Tony '78 911SC with BITZRACING EFI conversion kit |
This too is near and dear to my heart. PO installed it sidways...makes it nearly impossable to look straight back. Would love to remove and straighten.
Rob
Rob Black 1983 911 SC Coupe |
Funny.........I used to knock mine off accidently about once a year. I was buying those trapaziod double sided patches two at a time. Glue comes off with acetone or MEK. I'd say clean glass w/ alcohol before sticking mirror on, but I must have not been very good at it as it never lasted.
Hey Guys:
(Do what I say..don't do as I do ![]() How about more actual hints,..and less of the "me too" . I also would like a good answer on this. The stock mirror sucks, and is too "light" of mass and vibrates badly. A GM or Japanese mirror,...double jointed..would be just the ticket. Maybe we just buy another mirror...WITH the new button...and simply glue the button over the old button ????? ---Wil Ferch |
I just shoved a putty knife between the windshield and mirror base. The mirror just dropped off.
Information Junky
so perhaps it's just too loose. (read: mine doesnt vibrate, and I'll guess it weighs the same) Paul, "just shove it" is that your final answer?
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
My mirror is squarely blocked by the center mount brake light. I was looking for alternative mirrors (double jointed seems like it would work) and locations (thought about going to the right side, but realized passenger's head would block. I also thought about going lower, does anyone know of a problem that might result from that?
Jared
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Hey:
Why not like the "real" British sports cars that had the mirror close to to the dash ??? ....real low?? --Wil Ferch BTW...my mirror is on "tight"...but maybe the dual exhaust is helping the thing viubrate. FWIW...my friend's 911 suffers similary, and as you move the mirror around it's (single) pivot, it's clear that other mirrors have more heft...more damping mass...couldn't hurt. |
And I also replaced my rear view mirro with a local auto store cheepie. Looks better, saved a few grams of weight, doesn't vibrate like my OEM did, and looks OEM.
