1976 911S Targa
Can a caliper be submerged into brake cleaning fluid without damaging the caliper? What is the best method to clean the caliper? Thanks
That will likely damage the rubber seal on the inside. If you're rebuilding the caliper, then dunk it.
Tony G 2000 Boxster S |
French Import
I think if you did this you would have to split the calipers and replace the (4 I believe) o-rings that seals the halves together.
IIRC Eric Shea at PMB said that he only uses soapy water to clean the calipers, then rinse with clear water, and dry with compressed air; no solvents or cleaners.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Speed Dog's Chauffeur
Metal castings can have natural porosity
