Jocke's Avatar
Send a message via ICQ to Jocke
I need Info about 3,8 RS engine.
I have located a 3,8 RS (964) engine who is newely repaired. (340 HP)
So what type of gearbox fits on this? Kan I take the four wheel drive gearbox from 964 C4?
How much does this engine weight?
/J
Jocke Andersson
Reach me on ICQ - 317860713
Porsche 930 -77 SOLD
Modified, one of a kind in Sweden.
Check out my car @: http://members.cardomain.com/jocke
Old 08-28-2002, 12:37 AM
eion's Avatar
Send a message via ICQ to eion Send a message via Yahoo to eion
The RS 3.8 is basically a hopped-up RS 3.6 engine - with a few differences:
- larger piston diameter, but with the same stroke
- slightly lower compression ratio (11:1 vs 11.3:1)
- different Motronic version
- different rocker arms and valves, probably other minor changes
- more hp (300hp vs. 250hp) - the RSR (race) version has 325hp, not sure about your 340hp number (I think these numbers are correct, but they're coming off the top of my head, so may be rounded off).
No idea how much it weighs, but the RS 3.8 weighs about 150kg less than the RS 3.6, so I'm guessing the engine is either lighter or there's not much increase at all.
Can you put a C4 transmission on it? Probably, I don't think there're any really radical differences to a normal 3.6 as found in the C4 that'd stop you, but definitely don't take my word for it.
:edit - I mis-remembered what you said, thought you said 350hp rather than 340 (see what I mean about rounding off?)
'90 C2 Coupe - 104k miles
Old 08-28-2002, 01:05 AM
Jocke's Avatar
EXELLENT!
Thanks for the fast Info.
What does you think about the price? 13.500$
/J
Jocke Andersson
Old 08-28-2002, 04:02 AM
Bill Verburg's Avatar
The 964 based 3.8 RS was offered in 1993 only it was assembled in the racing department , used the same 76.4mm stroke as all other 964s but w/ 102mm bore for 3746cc displacement. It had 6 individual throttle bodies located close to the ports for better throttle response(interestingly the 3.8RSR raised them for better power) intake valves were 51.5mm(rather than 49mm), exhaust valves were 43.5mm(rather than 42.5mm), ports were stock 964 but cleaned up, cr was raised to 11.6(from a nominal 11.3). Power was 300PS @ 6500 torque was 360Nm@ 5250, engine weight was ~225kg
The 3.8 RSR engines developed from the 3.8RS are all out race engines developing an unrestricted 375 ps, w/ a 48mm restrictor in place that dropped to 360 ps
It sounds like the engine you found may have the racing cams(and perhaps the raised throttle bodies ) of the RSR. Theese engines are not really streetable needing to be kept above 4000rpm.
The going price here in N.A. for a 3.8 RSR w/ all the goodies seems to be ~$25-30K, so the price you quoted is probably reasonable if it is in good shape and as described.
Bill Verburg
Old 08-28-2002, 05:52 AM
Jocke's Avatar
Thanks Bill!
Can I in some how see if it got the raised throttle bodies and in that case how?
BTW You didn´t now if the C4 gearbox fit right on it?
/J
Jocke Andersson
Old 08-28-2002, 06:43 AM
Senior Member
john_colasante's Avatar
Here are some photos of a real factory 3.8 RSR I recently took:
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 08-28-2002, 07:33 AM
Nice pics John! Was that at the Glen? Anymore? the only pics I have are of the cup intake which is often confused w/ the RS/RSR intakes;
and this one of an RSR;
Bill Verburg
Old 08-28-2002, 08:42 AM
Jocke,
GET THAT MOTOR !!!! that would be the mother of engines!!! you'd kick A$$ at the races!!!
eric mckenna
78SC
Old 08-28-2002, 09:50 AM
Jocke's Avatar
Originally posted by stuttgart
Jocke,
eric mckenna
78SC
Yes if everything goes like I plan...
I´m planing on building me a real racecar under this winter, with fully carbon chassie and hopefully four wheeldrive.
The thougt I have is to even take it out on the strip and meet the four wheeldrive japs.
It´s not that fun to take my 930 out on a track or strip one day and the other are I´m out crusing or something.. It´s two kind of worlds I think. (Racing & Finish is tuff to have together..)
/J
Jocke Andersson
Old 08-28-2002, 10:02 AM
Senior Member
Yes Bill, that was at the Glen this past weekend. Here are more shots of the car, a genuine factory original 3.8 RSR:
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 08-28-2002, 10:03 AM
Senior Member
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 08-28-2002, 11:41 AM
beepbeep's Avatar
I have an idea!
Install low-CR pistons and turbocharge it!
P.S. Why 4WD??
Thank you for your time,
Old 08-28-2002, 12:25 PM
Keep us up to date jocke !! show us pic's as you put the race car together!.. I like what you have now .. so I KNOW the race car will be great lookin.
Eric Mckenna
78SC
Old 08-28-2002, 04:07 PM
Thanks John!
Bill Verburg
Old 08-29-2002, 06:03 AM
