2.2l Motor need help fixing hack job
Hi Guys,
as the title already states, the motor was rebuilt by our friends motor meister (going out of business) don't answer the phone and if not willing to help. my friend had his motor there for a rebuilt, took them 2 years to get it done, got the motor back and half of his motor harness was hacked up ... see pictures below, maybe somebody could point me in the right direction of fixing up that mess, so that he can enjoy a running motor was also converted to an electronic distributor with a red and a black cable coming out there see below dono where to connect here is a cable I dono know where to put it hanging in the middle in between the carbs where does the red wire positive out of the ignition coil go here comes the fun part I think all the colors are wrong was hacked up dono anything behind that another lonely cable any pointers are very much appreciated. also pictures of an original would be helpful. Thanks in advance. |
ROW '78 911 Targa
What year is the car and motor? It makes a difference...
The unconnected wires with the black covers on them aren't needed with carbs without warm up parts on the air intake and may be for MFI controls as well. Probably doesn't help with hooking yours up but, Picture of a new one here: Building SC and Mid Year Engine Harnesses
If it was me I would get the factory wiring diagram and start with the inhacked wires and figure out where each one goes to on my motor. I would get wires that duplicate the factory codes and get go work.
the car is a 1971
i downloaded the diagrams just have to print them on a plotter
still need to know where to connect the new elec. cap red and black cables
I'm curious how that 2.4/2.7 distributor can be on a 2.2?
That loose wire looks like one of the gray/red wires associated with the Zenith emission/starting enrichment stuff. Yours may have been removed long ago. Many were. |
Pretty evident he doesnt have the stuff he sent out.
Get back to as close to stock (factory) as you can..like with points. Bruce |
I have a 71T with standard distributer. I have 4 wires going to my CDI unit (versus your 5). I have a 3 prong plug with green/yellow, red and black colored wires. Also, there is a ground strap located on a prong just above the plug (where your lone red wirewith black prong protector is). Your extra wire may be for the electronic izzy.
Hope this helps Bob |
'73 911 T Targa
Here's a link to another thread where the guy did a nice job of installing the pertronix points while keeping it neat and being able to take it back to original at any time. It also includes a wiring diagram for using pertronix points with a CDI.
Pertronix Installation in '73 911E -- complete with photos |
thanks the ground strap is already connected on the front side seen in the picture with the black nut funny thing is they ran the engine on a stand and sent a video of it .. |
any other leads ?!?
ROW '78 911 Targa
Just because it ran in a video doesn't mean the wiring they used is the same as what they sent you...
PM me, I can build you a plug and play, doubt free, brand new engine and ignition harness, with correct color wiring and connectors made for your pertronix system and carbureted 2.2 engine without stray wires this weekend... Just the ignition harness wired for pertronix is an option as well. I would properly wire and run a red and black with a "T" connector to come out near the bottom of the dizzy and I'll send you the mating connector to attach to the pertronix wires. I could even build it so you could swap back to points if you wanted. I would also provide on the phone directions to help you wire it in... It/they would be in your hands by Thursday next week... (Need to know by Saturday evening for that to happen...) Or, use the schematics and build one yourself.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 01-18-2014 at 02:25 PM.. Reason: More detail on ignition harness |
Along those same line, from what I've heard (reading here) just because it ran in the video doesn't mean they sent you the actual motor that was running. Doesn't mean they sent you a new functional Pertronix either. Might be simplest to get it running on points first, then mess with the Pertronix if you want. Also, you say it is a 2.2, but the distributor is later, and should not physically be capable of fitting into a 2.2 case. Maybe you should eyeball the engine SN?
DG |
ROW '78 911 Targa
This is a picture of the standard ignition harness I build.
It looks like your wiring is totally incorrect based on the colors I see in the pictures you posted. Should be built with blue/yellow, red and black wires with a special Belden braided hollow shield cable for ground. ![]() Here is a picture of the correct engine and ignition harness together:
ROW '78 911 Targa
The power to the CDI on a stock ignition harness normally connects to the female connector I have circled in red from your original picture. It is switched power. Should be a red wire....
Under the radar
There was a recent thread you may want to check out.
70-71 engine compartment wiring questions
