ischmitz's Avatar
Send a message via Skype™ to ischmitz
3.2 DME rework - upgrade to 28pin socket
I just wanted to share a couple of iPhone shots showing the correct way to rework the DME PCB. This unit needed a 28pin socket upgrade amongst other things. While some simply add the four missing pins and call it a day I don't like that approach. To do this correctly I de-solder and remove the old socket and clean up real good:
Then I install a new high-quality 28-pin socket and solder it in place properly. The key to good soldering is cleanliness, the right solder and good temperature. Top row done:
and the finished product:
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 01-12-2014, 10:27 PM
muck-raker
kidrock's Avatar
that is very nice work, very clean.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 01-13-2014, 09:38 AM
Undocumented User
McLaren-TAG's Avatar
Well that and a good PACE desoldering rework station with vacuum control right on the hand piece.
Old 01-13-2014, 12:06 PM
ischmitz's Avatar
I wish I had a de-soldering station. Somehow I never could bring myself to justify one or a hot-air rework station either. This was all done the good old-fashioned way with a soldering iron.
The hot-air station might make sense at some point when it comes to the SMD D-PAK devices with large cooling areas soldered to the PCB.
Ingo
Old 01-13-2014, 12:54 PM
GaryR's Avatar
Send a message via ICQ to GaryR
Nice job Ingo! Considering it's my DME i'm very pleased...
Gary R.
Old 01-13-2014, 02:25 PM
Dme 28 pin
NICE JOB....but why converting it in the first place? any advantage?
Old 01-13-2014, 02:46 PM
Somewhere in the Midwest
MotoSook's Avatar
Nice work Ingo. I have forgotten how handy you are with these things...I'll keep in mind for future work
Old 01-13-2014, 02:47 PM
dshepp806's Avatar
Nice work, indeed. Good temp,..and clean!
BEST!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 01-13-2014, 04:39 PM
ischmitz's Avatar
The 28-pin socket can take the 27C64 (8 kbyte) and larger EPROMs all the way up to the 27c512 64k version. That way you can run the latest code from the "89 U.S. or ROW. In general I would always want to run the '89 code if I had a choice. There are several reasons for that:
- It probably has the most sophisticated part throttle maps and software - that makes for better drivability
- When you plan to get a custom chip for the DME the tuner most likely wants to work off the later code base
- The only EPROMs you can purchase today is the 28pin 27C512. If you buy a smaller 24pin EPROM its either NOS (new old stock) or used.
This DME will get a custom-tuned chip later. Depending on what the tuner works on I would always want to start with the latest base maps. Some only work on the WOT maps from what I understand.
Regards,
Ingo
Old 01-13-2014, 04:45 PM
Chain fence eating turbo
Nice wetting Ingo.
Old 01-13-2014, 06:37 PM
Tags
cold solder , dme , dme fuel pump no spark , no start , repair
