-   -   Started on my engine conversion (http://forums.pelicanparts.com/porsche-911-technical-forum/793030-started-my-engine-conversion.html)
timmy2 02-02-2014 09:17 PM
Took a few minutes tonight and looked at my factory wiring drawings. Something was nagging me in the back of my mind...
The '74-'75 engines DO NOT have a fuel pump relay... They are fed from Fuse 12 coming directly from terminal 15 of the ignition switch. The safety shut off relay was added in '76
Maybe someone added a relay to your car, or it is for something else.
May I suggest you add one for safety? A Ford Bronco II roll over switch or similar would be what I would use.
For whatever reason the '74 factory workshop drawings are all black and white. while every other year is in color... I am going to do a wire by wire comparison of function and routing with the '75 diagram to see if the wiring is the same and if one could assume the same for the color codes.
EDIT..
If anyone has a color factory current flow drawing for a '74 I would like to borrow it to copy on our color print machine and return it to you.
Bill Jennings 02-03-2014 04:21 AM
Dennis,
Its a long way for me to post the original to you but if this is what you are looking for PM me. I don't suppose you have a chart or can make a harness for a C3?
http://forums.pelicanparts.com/uploa...1391429691.jpg
http://forums.pelicanparts.com/uploa...1391429729.jpg
http://forums.pelicanparts.com/uploa...1391429774.jpg
http://forums.pelicanparts.com/uploa...1391429815.jpg
http://forums.pelicanparts.com/uploa...1391429852.jpg
http://forums.pelicanparts.com/uploa...1391429891.jpg
http://forums.pelicanparts.com/uploa...1391429926.jpg
Cheers
Bill
mreid 02-12-2014 04:43 PM
I figured out the wiring. Dennis was right, a PO wired one of the relays in the engine panel to power the fuel pump. Once I got all the tape removed I was able to ring all the wires and move several positions in the engine harness plug to match the chassis harness. I also added the air filters:
http://img.photobucket.com/albums/v6...psr1nodw7j.jpg
http://img.photobucket.com/albums/v6...psvuoruxlo.jpg
I little more wiring work and some mods to the engine electrical panel to mount the MSDs and this bad boy gets installed!
toddu 02-12-2014 05:15 PM
Are those blaster coils? Where are the boxes going?
Todd
timmy2 02-12-2014 05:31 PM
Nice job detecting the custom wiring gremlins. :)
Your engine looks great.
And a special thank you to Bill for scanning and sending me a copy of colour diagrams. :)
mreid 02-12-2014 05:38 PM
They are blaster coils and the boxes are going where the old box, accumulator, and fuel filter used to go. Pictures this weekend.
jpnovak 02-12-2014 06:32 PM
Looks great. Bring it out to the HCR. You can finish by March right?
mreid 02-12-2014 06:37 PM
I'm already signed up and plan on being there. I should be on the road by the end of the month.
jpnovak 02-12-2014 06:46 PM
Great. We are all looking forward to the event. It will be nice to meet you.
mreid 02-13-2014 06:58 AM
You too, Jamie. See you there!
Flat6Heaven 02-14-2014 10:39 AM
Congratulations on the build! As others here, I am looking forward to "final" pics!
Good luck with everything.
trader220 02-14-2014 02:18 PM
Thats a work of art!
mreid 02-15-2014 03:48 PM
Got a lot done today!
This would have been entertaining to watch. I had to remove the stock exhaust while the engine was dangling from the hoist. What a pain!!!
http://img.photobucket.com/albums/v6...pspx1qvsw6.jpg
Everything else went pretty well. I grit blasted all the tin and got it painted. Going back on tomorrow. Installed the flywheel, clutch, and tranny. Tried to bolt on the starter, but the studs are too long for the barrel nuts. Off to the store tomorrow. It's really starting to look good!
http://img.photobucket.com/albums/v6...psk8hocuvi.jpg
http://img.photobucket.com/albums/v6...ps3xeevvre.jpg
http://img.photobucket.com/albums/v6...psdbolte6r.jpg
http://img.photobucket.com/albums/v6...pshujrfdev.jpg
mreid 02-23-2014 04:11 PM
Engine is going in next weekend! I ground out the old sway bar brackets and welded in the new ones, cleaned and painted the spring plates, installed he Rebel Racing bushings and coilovers, and finished the engine wiring and MSD harness. All in all, a productive weekend!
http://img.photobucket.com/albums/v6...psscsrzpar.jpg
http://img.photobucket.com/albums/v6...psawrbcd8g.jpg
http://img.photobucket.com/albums/v6...psgrm6jdzg.jpg
Once the engine is in, I still have to install the front oil cooler, but at least I move to the front.
mreid 03-01-2014 09:59 AM
MSD boxes installed and wired:
http://img.photobucket.com/albums/v6...psqnlrdarg.jpg
I'm now going to attempt to pull the mechanical speedo cable with the wires for the electronic version attached for one easy remove/install. Fingers crossed!
cmonref 03-01-2014 12:05 PM
In your picture of the MSD boxes, what is the silver annular ring on the outer half-shaft end, between the bolt heads and the boot retainer?
mreid 03-01-2014 05:22 PM
Good question?
mreid 03-02-2014 01:39 PM
And then...
...it's in!
http://img.photobucket.com/albums/v6...ps79tnl0oe.jpg
http://img.photobucket.com/albums/v6...psoww4mqx4.jpg
http://img.photobucket.com/albums/v6...psi3lxwkqj.jpg
http://img.photobucket.com/albums/v6...psnrwz5f7c.jpg
Next up:
- connect everything
- reinstall rear bumper
- move to the front and install front oil cooler
Flojo 03-02-2014 02:15 PM
Great "marriage"!
G50911 03-02-2014 02:44 PM
sweet! after it's dialed in, don't forget to post some vid clips!
