to do list, help please!
I have a (new to me) 81 sc with 118K on it. The motor and tranny are out, and I would like a list of all the repairs/replacements I should do that are best done, or can only be done, with those big pieces out of the way. I don't have access to a lift, so it's a good time to take them on.
I am starting with the gas lines, clutch cable, flapper boxes and cables.
Thanks!
Old 02-02-2014, 06:52 AM
French Import
zippy_gg's Avatar
The "triangle of death" comes to mind, very easy with the engine out.
Also the 2 speed sensors and the CHT sensor as their casing is probably crumbling apart.
As part of the slippery slope now would be a good time to replace the rear suspension bushings, rear wheel bearings, and possibly the rear shocks. All of this is much easier with the engine/transmission out.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 02-02-2014, 11:40 AM
ROW '78 911 Targa
timmy2's Avatar
This will keep you busy...
Long term & Commonly Neglected Maintenance
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-02-2014, 11:54 AM
crustychief's Avatar
I would seal the "triangle and replace the vent hoes that goes from the breather to the oil tank. As far as the reference sensors and CHT, the SC's didn't have them.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
French Import
zippy_gg's Avatar
Cool, I didn't know that as the Carrera is my first 911.
Gilles & Kathy
Old 02-02-2014, 12:03 PM
French Import
zippy_gg's Avatar
I forgot to mention the rubber brake lines as a good subject for replacement.
One of the best pieces of advice I received early on from this forum was to replace everything rubber.
Gilles & Kathy
Old 02-02-2014, 12:05 PM
Laneco's Avatar
Triangle of death - always good to address. Make sure the air box has a pop-off valve (if not, then install one). Sure mucho easier to do a valve adjustment with the engine is on the bench. Just sayin'...
angela
Hello
Old 02-02-2014, 04:10 PM
