3.0 ignition distributor recondition
Who reconditions these distributors at a fair price?
Try not, Do or Do not
Aaron Burnham
Burnham Performance 1071 Avenida Acaso ste.D Camarillo, Ca. 93012 805-240-6931 rennwerks@hotmail.com
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Senior Advisor
Barry Hershon IAE Inc.
Jerry Woods JWE Motorsports | Professional Porsche Race Car Coaching Upgrades Trackside Support Setup and Maintenance
08 Cayenne Turbo |
Define fair price. I had one done by Barry and one by Jerry both were 500.00 for total rebuild and setup for carburetors. Was about 5 years ago.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Senior Advisor
thats fair
08 Cayenne Turbo |
Fleabit peanut monkey
I have a working fine 81 US dist on the shelf sitting next to my 964 cams. Bought both in the 90's. New Bosch from Beck Arnley and Elgin 964's from Engine Builder's supply.
They could be called Boxster parts as that's where they sit....in a box. If I ever get around to this "wild-hair" upgrade, it will be sad to take one of the two functioning distributors and have it set up to better match the cam profile. It will be sadder still to have to pay $500+ for it. But I will do it, whenever the hell that occurs. :-)
1981 911SC Targa |
ROW '78 911 Targa
To the OP,
What is wrong with yours? Might want to do a search on rebuilding them yourself. There have been a few post in the last few days about this. Under $100 worth of parts for new everything.... My parts to redo the bushings and shims were about $50. Guess I saved $450 in labor at $225 an hour, as it took me about 2 hours to do the work. Hmmm, Maybe I need to raise the prices for the harnesses I build! ![]() Sent from my iPhone using Tapatalk
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 02-15-2014 at 08:08 PM.. |
I bet I can do that.
Regarding fancy-pants advance curve work wrt the 964 cams, the 81 SC basically goes right to 19-24 btc total advance (or there-a-bouts) by the time you hit 3,500 rpm. I can't see huge benefits from any curve work done - I mean, it's a 180 hp car - except for taking the lid off and allowing the total advance to maybe hit 27-29 total providing a bit more spunk at top end. Can that be done by a DIY guy? There are several DIY threads about rebuilding as I recall.
1981 911SC Targa |
Bob, yes, it can easily be done, simply take the top half down and bend the stops to get more advance, or change springs to get a quicker advance.
You can lock out the vacuum plate as well if your not using it, but it can provide top end advance with CIS if the vacuum is pulled from below the throttle plate. All you need to do is pull it apart clean,lube and you will likely get all the advance you need. One of the most common problems is that the little plastic feet on the advance shaft can sometimes get brittle, crack and break and then the advance can get hung up, or the bottom gets filled with rust and crud, sometimes a spring may be broken. The best way to test it is in the car with a timing light, see how far the spark advances, check it at 500 rpm increments all the way to 3500 rpms, Is it close to the factory curve? Don't drink the kool aid, it ain't brain surgery.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 02-15-2014 at 08:17 PM.. |
ROW '78 911 Targa
Wasn't referencing you Bob... I was typing while you were posting...
![]() And poorly at that... Fixed my post...
Topic for another discussion, I guess to be fair to the OP. Thanks for the food for thought.
1981 911SC Targa |
I misspoke on the vacuum advance, I am not sure, about getting more advance, or wether it matters if it is above or below, and the way that the SC vacuum works. Sorry.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
I was asking because I just installed a bitz EFI kit on a non running car I just bought. When I first started it up, it purred like a kitten. I went to take it for a spin, it then started sputtering, and then all it would do is idle. If you tried to rev it, it would cough, miss, and not build RPMs. I checked my valves again, checked the timing, replaced CDI with an MSD, new spark plug wires, new spark plugs, new cap, new rotor button... Everything new. I was thinking that maybe my distributor was bad. I did see the post about cleaning and lubing the distributor, and I think I will go that route. I refuse to pay someone $500 to do the work that I could just do myself. I think I found the culprit to my problem. That stupid GREEN wire!
Kinsley 1980 SC Targa - MS2, EDIS |
Vacuum advance doesn't do much on WOT. It provides advance at cruising rpms where more advance helps with emissions and mileage. The source is below the throttle plate where you pull a ton of vacuum when cruising, and it does little at WOT as there is little vacuum. Mechanical advance is doing all the work when it's floored.
The vacuum retard is below the plate as it want's vacuum at idle to retard the timing for better emissions. So as you come off idle, and vacuum is created above the plate, the vacuum advance starts assisting the mech advance. What I don't know is if all vacuum advances are like this. Try this on your SC, pull the vacuum advance and check for suction at idle. There should be none. If you have both hoses, one should have vacuum and one should not at idle.
1981 911SC Targa |
Oh well, getting way off the track of the OP - back to regularly scheduled programming (apologies for the bad info)
