Would this manifold rust would be a problem?
it could just be brushed or blasted off right? looks like its just surface only but since its the mating surface i figured I would ask the experts before I spend some money.
1985 Iris Blue M491 911 Coupe |
Almost Banned Once
You'd have to take heaps of metal off to use those. No difficult but you have to get the surfaces flat.
I guess it comes down to, How hard is it to find 993 clams in good condition second hand?
- Peter |
not that hard, but this one is around a 3rd the price a good one is. I thought if it could be spruced up with a media blast it might be worth it. If they need something more than that I probably wont bother. Do you think its not worth the effort?
Basically my my thinking is you can get a decent used set of these for 500 if youre lucky, but its been a while since Ive seen any that cheap. Then I'll pay to clean then up a bit and cut and reweld one side of the manifolds so they match up to a 3.2. If I get this manifold for 100 and another not quite as rough one I see on sale for 250ish I think I could come away from it all for 500. On the other hand if its more trouble than its worth for $150-$250 savings I'll just try to get lucky with a nicer set.
abit off center
Just wire wheel them and see what they look like. Isn't there a gasket also used on these?
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
To my eye, that's simple surface rust and will clean up nicely with a wire brush. It doesn't appear to me as bad as Peter suggests. If you see signs caking rust, you'll have to find a way to resurface or replace all the flanges.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Agree it's surface rust. A wire wheel will make them look like new. The gasket will make sure they won't leak. I think they are fine
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Project Addicted
I'd hit this with a flap disc to smooth it out and use it. Would take 5 minutes, no more.
Jon 1966 912 1976 911 3.4 Backdate Project 1986 944 |
After wire-brushing, would you recommend some sort of hi-temp paint to prevent this happening again?
i would use sandpaper on something hard and flat to keep the surface flat.
I nice new gasket will exclude air and moisture so I wouldn't use paint.
I'm thinking belt sander with 80 grit would make those as good as new...
Gary R. |
blast or wire wheel it and your good to go. dont paint it . they only got rusty from sitting around off of the car. once they are back on the gasket will keep away the moisture
82 SC , 72 914 |
thanks everyone. ill go ahead with them and try using a brush wheel
