Question Cat-Bypass
What is the trick to removing the cat exhaust bolds??Ther are fused in place. Any tip or ideas on how to get them off?? Have a nice new stainless steel by-pass and cannot get the old one off.....
Thanks,
Jim
jevose
82 911 SC
88 930 Turbo
Old 09-08-2001, 09:24 AM
mideastmafia's Avatar
Send a message via AIM to mideastmafia
Post
take a heat torch and get them REALLY hot and spray wd-40 on them. then try to take off with vice grips. if it dont work then just saw them off and replace the bolts.
SHAUN
Old 09-08-2001, 09:28 AM
Post
The shop I used had to chisel them off. Hopefully the stainless replacements with antiseize compound won't give me the same trouble.
Old 09-08-2001, 09:33 AM
carnut169's Avatar
Post
Jim- I have recently installed a cat test pipe, and replaced my cat so I do have 1st hand experience.
First- If you have access to a lift it is much easier- remove the left rear wheel as well. Soak your bolts in liquid wrench or a similiar product. WD40 may work as well. I had to hit the bolts 4-5 times- you want to tap the bolts w/ a wrench which will help the fluid to spread after each soaking.
If you have not already done it, be sure to buy new bolts and gaskets first!
87 Carrera Cabriolet
Old 09-08-2001, 09:34 AM
rstoll's Avatar
Post
Drill a 1/4" hole through nut and screw, twist it off with wrench. Replace with new screws and nuts.
Robert Stoll
83 SC
83 944
Old 09-08-2001, 10:21 AM
Senior Member
Doug Zielke's Avatar
Post
Forget about penetrating oil, snake oil, and mid-nite oil. Just cut the bastards off with a Dremel and cut-off disc. And the rstoll drill method works great too. Have a nice sharp cold chisel handy, along with Mr. Hammer...sometimes the bolts are so rusted, you can just knock the heads clean off.
Use Never-Seez on new bolts. S.S. not nessesary (or even desirable) over regular Grade 5 fasteners.
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
The Blue Bomber's Website
Old 09-08-2001, 12:21 PM
