Banned
An AFR meter on the cheap ?
I'd like to buy an AFR meter but right now I dont want to spend that much, so...
What about finding an old wideband lambda probe (heated), placing it at the exhaust end and taking readings with a voltmeter ? Will it do the job ? |
Straight shooter
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Why not buy an innovate LC-1? Around $160. Includes the gauge for instant readings. Plus it will log the data stream for later analysis-- instant information is good, but you can't really make CIS adjustments while you are driving. . .
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
Banned
304065, the purpose is to tune a new system, so a fixed solution is acceptable.
But 14point7 really has some cheap options... |
I did check out the docs and I would be concerned about getting this thing to work. I assume it is made in China as the instructions come in English and Chinese. For my money I would buy the Daytona-Sensors WEGO unit from out hosts and have something that is well made, good support, good software, good data logging [this is important] and a complete package with great docs. I have been using mine for 5 years and love it. But I am biased in that I am a happy customer. Innovate is good too, but gets expensive as you add on to get data logging etc.. Just my 2 cents.......You could save $100.00 and not be happy with what you end up with.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
You do need some electronics to go with the wideband sensor. They are not like the old O2 sensors that put out 0 to 1 volt
inaccurate, but inexpensive...better than narrow band though
14.7 stuff looks nice, seems to be the Bosch sensor which is good
wonder what the GUI is like ? OP: are you FI or Carb? If FI, do you have a tunable ecu or is this just for monitoring purposes |
Straight shooter
I haven't used 14Point7 personally but I know of them as the cheapest controller (The DIY is $35) out there. I've used Innovate LC1, LMA1/2 since 2005 which also use Bosch sensors but do carry a price tag. The sampling output from the controller to ECU interface on both Innovate does deviate from requested which can cause datalogging during tuning to be off by about 1 AFR point in my experience.
My current build will be using the controller EAW-52 as part of VEMS US | Versatile Engine Management Systems engine management installation along with EGT probing on the same gauge. EAW-52 Wideband Controller | VEMS US This gauge can be installed as a stand-alone option as well similar to 14point7 and Innovate... adding EGT monitoring for cheap is icing on the cake.
1984-911 M491
1984-911 TLC......SOLD |
As far as I can tell, every response above has suggested products which require hard mounting/semi-hard mounting your sensor in place (i.e. gauge provided is powered by vehicle 12v lines). If you're like me and solely wanted a device for vehicle calibration, the Innovate LM-2 is your cheapest bet. Even AEM and Zeitronix require wiring the gauge portion into your vehicle.
Thanks, Matthew |
In my experience you cannot get any usable information without welding a bung in the right place in the exhaust. Period. And I have tried.
Straight shooter
I think he meant wiring wise.
Innovate has a clamp that samples the stream at the tip. It works perfectly well with a collector that inserts up the tail pipe. Very popular for accurate reading and tuning with professional dyno operators. Pics (pardon the fart-can style exhaust): ![]() ![]() I have one downstairs for tuning on cars that don't have a wideband as part of permanent monitoring.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 03-13-2014 at 02:25 PM.. |
Thanks, Matthew |
Been there done that. Ideally you want to test on the road with your driving cycle and then study the data.
AEM and innovate have systems for under 200$ that include guage, sensor and controller. These are the new type with the controller built into the gauge.
84 930 18 Cayman GTS |
AutoBahned
The Innovate LC requires a serial port to connect to a PC. Does anyone still HAVE a PC with a serial port??
a $5 serial port to usb adapter will solve that problem....
1986 930 |
AFR gauge
Innovate also makes a round AFR gauge that can be mounted under the dash or in the engine compartment. They are available in either blue or red displays. Cost is about $200 for the complete kit. I installed on in my SC coupe to use while tuning the CIS injection.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Chain fence eating turbo
I run an Innovate MTX-L. Amazon I believe has them for like $160 IIRC. It's a self-contained unit with data port out and EFI out.
