RazorRacer's Avatar
what is this squeak?
My p-car has a new squeak after last weekend's DE. Can you help me identify what it is? This is what is sounds like as I gently push up and down on the front right of the car.
squeak
I have been told that my shocks are weak, too.
Stopped racing and became a drummer
Old 09-09-2002, 04:39 PM
Somewhere in the Midwest
MotoSook's Avatar
LOL..sounds like your choking a rooster!
Seriously....sure sounds like shocks.
Old 09-09-2002, 04:44 PM
RazorRacer's Avatar
Geez, for $500 I can get all new shocks. On the other hand, is there any way to lubricate the squeak out of the shock?
Old 09-09-2002, 04:54 PM
sayah's Avatar
Sounds exactly like my car, WAD its those poly bushing crying out for some lubrication.
sayah
Old 09-09-2002, 04:57 PM
Can't help with your question aside from checking hte suspension bushings. But that if ROFL funny!
Old 09-09-2002, 04:58 PM
MotoSook's Avatar
Shocks is just my guess as I have had such sounds from my other cars that ended up being shocks. I don't know if lube is you answer. Repost with a different title (w/shocks) and see who bites. There have been lots of shock related posts in the past so I'm sure there are a lot of BTDT guys.
Good luck. And stop choking that rooster, man!
Old 09-09-2002, 04:59 PM
RazorRacer's Avatar
Sayah, where are the poly bushings (shocks or suspensions)? What is a good lubricant?
Old 09-09-2002, 05:03 PM
Chuck Moreland's Avatar
That does sound pretty funny. As in Ha Ha.
You were pushing up and down on the fender repeatedly to make that happen? Or did you push just once?
My '77 just started making a similar sound after my last track outing. I would describe it as a squeeky gate door sound. Just slam the door once and it creaks for several seconds.
It seems that it is coming from inside the fuel tank. I assume it is the fuel level sending unit, yet the guage appears to working fine. It's the damndest sound, just creaking away.
Chuck Moreland - elephantracing.com - vonnen.com
Old 09-09-2002, 05:07 PM
Embs's Avatar
I think gnomes are getting it on in your trunk!
Old 09-09-2002, 05:09 PM
RazorRacer's Avatar
Yes.
Man, I'm glad ya'll are getting such a laugh at this.
In that case I'd check your front bushings. Particularly the sway bar.
Do you have stock bushings?
Try shooting a little wd40 on the bushings, one at a time, and see if it goes away.
Old 09-09-2002, 05:12 PM
RazorRacer's Avatar
Yeah, it's the sway bar bushing (one or the other). The WD-40 didn't penetrate either from the sides. I'll have to keep oiling them until it goes away.
Muchas gracias all for helping me.
PS: maybe I have a future in sounds & animation?
Old 09-09-2002, 05:44 PM
CEO CEO is offline
CEO's Avatar
Send a message via AIM to CEO
Lightbulb Not so fast!
I had this same squeak about two years ago on the right front also and I thought it was the same thing the bushings, I oiled and oiled the hell out of them, but to no avail. So I gave up and took it to the Porsche dealer and the mechanic there said that it was the torsion bar. The grease and worn thin and stopped it form twisting properly. Well sure enough we put it on the lift and took out the torsion bar and lubed it up and that was it no more squeaks. That would be the cheapest and best option to try first. And a lot less trouble.
But that is just my .02 I am sure that some people would disagree with me though.
Either way let us know what it was or what you did.
Regards, Kenneth
Kenneth
Silver 81' Targa
Old 09-09-2002, 10:26 PM
Iv'e been listening to this interesting sound for 5 minutes now and can't turn it off, even when I close the thread. Sounds better than some of my son's rap CDs though.
Chuck
1987 911 Targa
1962 C182
"Dirt is permanent. You can move it around, but you can never destroy it."
Old 09-10-2002, 08:00 AM
MotoSook's Avatar
Chuck, you should move to a chicken farm if you like that sound so much. And teach you boy how to choke chickens.
Sorry (really) Razor, I couldn't resist. Smile, it's only Tuesday.
Old 09-10-2002, 08:05 AM
Sean Hamilton's Avatar
Re: what is this squeak?
Originally posted by RazorRacer
My p-car has a new squeak..........I have been told that my shocks are weak, too.
If your shocks are knackered the bounce squeak will always be there.
Determine which side of the car is it emanating from and can jack THAT side (the front) of the car up so that wheel is off the ground. Let it down again - has the squeak is gone? (temporarily) if so I'd say it's your torsion bar, not the shocks.
Cheers, Sean.
94 911 Carrera 2 993 Cab
http://www.pelicanparts.com/gallery/Sean_Hamilton
Old 09-10-2002, 08:34 AM
RazorRacer's Avatar
Re: Re: what is this squeak?
I'm starting to believe it's my shocks. So $500 needs to be put into the p-car fund.
Old 09-21-2002, 11:41 PM
B58/732
BlueSkyJaunte's Avatar
I get the same squeak from my left front. Only after it's rained, though. Fortunately these days it's a rare occurrence that I'm driving the P-car in the rain.
ΜΟΛΩΝ ΛΑΒΕ
Old 09-21-2002, 11:57 PM
Send a message via AIM to 82SC
i had that on my 82SC
seemed to come and go...especially bad on cold days...
I'd get some white lithium grease and get under the car and lube everything...the sway bars have brackets with rubber bushings...put some bewteen the metal and the rubber...
mine is gone but this was during summer...maybe it will be back this winter
do that before spending money on shocks...
I thought shocks were bad when the car ocillated when you pushed down on it...
MJ
Old 09-22-2002, 01:27 AM
RazorRacer's Avatar
I jacked up the squeaky side and bounced the wheel with a piece of wood on top of a fulcrum...no squeak.
I lowered her back down and still...no squeak.
Thanks Sean. Saved me some big bucks.
Sounds like I need to follow Ken's advice and remove the torsion bar and lube it up.
Old 09-23-2002, 05:26 PM
