kdubb's Avatar
Question Need a Battery expert!
For the past 6 years I had a 34/78 red top optima in my car with 800CCA. It recently died. So I decided to put a 34/78 Yellow top in because I have an aftermarket stereo system with amp. The Yellow Top only has 750CCA wich prompted me to research what type of battery is needed for my car. The only thing that the owners manual says is 12V, 88ah. So my question is, is it ok to put a battery in my car with high CCA, but lower Ah than suggested in the manual? The optima has 55ah.
Thanks for your help! and Yes, cost is a concern.
Old 03-27-2014, 08:05 PM
Somewhere in the Midwest
MotoSook's Avatar
It'll be fine. Some of us run smaller batteries.
Old 03-27-2014, 08:34 PM
80-911SC's Avatar
Yea .. you will be fine ..
battery technology today is a little better than when your car was built also ... plus you have benefit of not having that nasty acid box in the front ...
some of the guys here have what looks like a lawn mower battery in the smugglers box ....
Old 03-27-2014, 09:18 PM
kdubb's Avatar
Great!
Thank you for responding!
Kevin
Old 03-28-2014, 05:05 AM
T77911S's Avatar
its not the battery, its your alternator.
these kids that put those mega watt amps and all the lights in their cars and have a 90 amp alt are killing their batteries and alts. you can add a capacitor that can help with peak power surges like with a lot of bass.
if your system is really big, go with a higher output alt.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-28-2014, 06:19 AM
That's it! Plus, bigger batteries put more stress on the alternator when they're
in a low charge state.
Old 03-28-2014, 07:03 AM
kdubb's Avatar
Just a small system upgrade
My system is not competition, but I do have a capacitor. Upgraded my system for when the top is down. I was told by Optima that the yellow top would be better for me. Not understanding batteries and how the wrong battery can impact the entire system. I did not want to make a mistake that would cost me down the line.
Old 03-28-2014, 07:08 AM
T77911S's Avatar
i would be concerned that the alt is not big enough, filtering of the output of the alt(you have done) and then matching the battery to the charging output of the alt.
if you want to be picky about it that is, different types of batteries prefer different charging voltages.
i dont know how much of a differnece the voltage will make on the life of a battery. you may be putting out 13.8 and optimiun for your battery may be 13.2. is that going to REALLY do anything to the battery, probably not. like i said, if you want to be picky.
your last battery had a long life so i would not worry about it.
here something for your late night entertainment
http://batteryuniversity.com/parttwo-42B.htm
RACE CAR:: sold
Old 03-28-2014, 08:58 AM
kdubb's Avatar
Yes there is a date stamp on Optima batteries
The one that I purchased but have not installed is 02/14
Old 03-28-2014, 09:13 AM
kdubb's Avatar
Thank you T77911S
I'll take a look at it.
Old 03-28-2014, 09:15 AM
Really? Is the cell voltage different on a bigger battery?
Rick
88 Cab
Old 03-28-2014, 10:47 AM
RETIRED
Joe Bob's Avatar
That's why it is a good idea to charge a low battery on an external charger. Alternators maintain batteries, they shouldn't be used to charge a low one unless there is no other choice.
2012 ML350 3.0 Turbo Diesel
Old 03-28-2014, 10:49 AM
Stress is a physical force or pressure. Stress over time is something different that relates to reliability.
According to SAE J56 to obtain the rated current of the alternator you run it at rated speed (nR = 6000 RPM) connected to a battery in parallel with a resistive load and vary the resistance to get the specified test voltage (Vt 13.5 V ± 0.1 V). You also have to run it for 5 minutes after it has reached thermal equilibrium in this state. After it has stabilized the current into the load is the rated output current IR.
Wouldn’t this imply that the size of the lead acid battery in parallel with the load would have nothing to do with the magnitude of the current the alternator outputs if 13.5 is the charging Voltage? Sure it will take longer to charge a 100 Amp-hour battery to full charge than a 60 Amp-hour battery but are you saying the diodes are so critically sized that there is an observable difference in reliability due to the (longer) period of thermal stress?
If you are using more energy than the alternator was designed to provide you have a problem. If the only difference is a bigger battery no worries.
Rick
88 Cab
Old 03-28-2014, 11:08 AM
nineball's Avatar
take a look at this thread. almost 4 years later and i am still using the same used battery i installed in the thread.
another battery install thread
capacitors do not help if you are drawing more power than your system can supply. it's amazing how many people think that adding something else in your charging system that requires power to operate will magically make the system have more power. they can help regulate surges but after reading what i have posted below you will hopefully see the light
this is an old article and while the links may not work anymore the ideas will hold true forever.
After studying a little history on large 1 Farad capacitors in car audio, you'd be amazed that they even sell at all. How useful are they? What do they really do? Will a Cap 'improve' my sound quality? Will it Prevent my lights from dimming? Will it audibly affect my audio system in any way?
Before you get the truth to any of the above questions, chances are, you've probably spent $100 or more on one of these devices. However, let's study a little history regarding this issue.
A long time ago, in a land far away, 2 elves...Ok, Richard Clark & Wayne Harris (Carsound magazine and the inventor of DB Drag, respectively) separately came up with a solution to preventing their lights from dimming.
WHO WERE THESE GUYZ?
As you may know, Richard Clark is one of the founders of autosound2000 Tech Briefs, Carsound magazine, and a published author of the industry of mobile electronics. In SQ competitions, he posted a record of 1234 1st place finishes, and only ended up NOT 1st in his first event. I've heard that he had minor system problems, but judging by his record, he must have corrected it. (evidently, he needed a Capacitor )
Wayne Harris was previously a leader at Rockford Fosgate in their development. Later, in his free time, he created the organization we call DB DRAG. Wayne was the first SQ World Champion from the organization we know as IASCA (International AutoSound Challenge Association).
Both of these gurus are both legends, and considered the leading experts in the field. During their competition days, both guyz came up with a way to assist in the prevention of voltage drops. In SQ competitions, the look of your system is actually more important than the sound, and having your lights NOT dim under high playing levels is a competitive advantage.
As you may know, amplifiers are made up a bank of little capacitors, resistors, etc. What has been common engineering knowledge is that capacitors store energy, and more or bigger ones assist in balancing the power supply.
Wayne came up with the idea of putting several dozen 'little' (approx 100uF) capacitors on a circuit board to 'extend' the power supplies storage. At about the same time, or shortly afterward, Richard came up with the idea of one huge mondo capacitor (I believe it was 800,000uF or 0.8F) to do the job.
Eventually, Richard won. The large cylindrical tubes won over the complicated 48 caps strapped to a circuit board. However, what did this really accomplish? Let's start here:
WHAT IS A CAPACITOR?
Basically, capacitors are an energy storage device. Large, 1 Farad or more
capacitors store energy (electrons) between their plates. Capacitors differ
from batteries because batteries store energy in the form of chemical
energy--and rely on acid and lead plates, as the place of storage. For a more detailed
description of a capacitor, go here:
http://www.eatel.net/~amptech/elecdisc/caraudio.htm
Then on the right hand side, scroll down to CAPACITOR. Keep in mind the use
of capacitors in an audio system.
WHY DO PEOPLE BUY CAPACITORS?
The number 1 reason would have to be because their lights dim when their
system is playing HARD. In car audio, we are told that a capacitor is
designed to prevent the voltage drop associated with your lights dimming.
The number2 reason is that it is rumored to 'improve' sound quality or
'stiffen' the power supply/source.
WHY DO MY LIGHTS DIM?
Headlights brightness is in direct proportion to the source voltage. For
instance, if your car is running, system voltage is ~12.5 -14.4 VOLTS. Your
lights will be much brighter than when your car is turned off--where battery
voltage is ~12V. Most car alternators put out between 75 to 120 amps of
current. When this current draw threshold of the charging system is
exceeded, system voltage will drop as power demands are now shared by the
alternator and the storage devices (battery & cap). We are using battery
reserves beyond this point until the demand lessens
When playing your system really hard. Your lights dim because your
alternator can't keep up it's charging voltage (around 13.5V) and therefore,
demand exceeds output. When this happens, your electronic devices are
dipping into the power storage of the battery. Since the battery stores
power at ~ 12-12.5V, there is a 1.3 to 1.8V drop in voltage available. This
in turn is why your lights dim down.
HOW MUCH POWER DOES A CAPACITOR STORE?
1 Farad = 100 joules or 100W/second
850cca battery = ~2,200,000 farads
For storage purposes, you'd need ~2,200 1 Farad capacitors to equal the energy of your battery.
Due to its impedence (ESR & ESL), a cap's energy is only 50% available. What's worse, is that in order for a 1 Farad cap to discharge, first the alternator output must have maxed out, and the voltage must have dropped around 1.5 volts. But I thought a cap was supposed to prevent that (voltage drop)!!!!!????? Yep, you got the point.
continued.....
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 03-28-2014, 11:20 AM
nineball's Avatar
IF A BATTERY = 2,200 CAPS, THEN WHY BUY A (PUNY) CAP?
My question exactly. Marketing is the reason why people buy caps. In many cases, upgrading wiring will help your system get the maximum transfer of current. Once that has been reached, adding a capacitor may have a minor effect on your system. 50W over the course of a second is not a lot of power considering an amplifier may draw 2000W to put out 1400 watts. Let's look at the situation from a resources standpoint.
Alternator 80 amps
Car accessories (minus stereo) 40 amps
A large Car Audio system (DRAWS ) ~200 amps AT FULL OUTPUT
In this case, you have 240 amps of draw, but only 80 amps of current from the alternator. In your case, you need 160 amps x 12 volts or or let's say 1920 watts of energy. Since a cap stores 50W, how much of a difference do you think it's going to make? A cap is basically a peashooter. W+e need a Howitzer cannon here, to do the job well.
Also, Once a cap is discharged, where does it get it's power from? The alternator, which is already overloaded. Once a cap is discharged, it's worthless. Like SWEZ says, ・.The cap already shot its wad, an does limp til recharged・ I知 not so certain I will allow him to babysit my kids, but you get the drift. (I never said it quiet like that... and oh...I'm great with kids!)
SO, WHAT IS A CAPACITOR GOOD FOR?
1. Audio Jewelry- impress chicks with large cylindrical shiny thingy
2. Extra weight in winter time
3. A very POOR... BUT expensive distribution block
4. A projectile in the event of a crash
5. Rolling pin--for cooking purposes
6. A neat thing to tell your friend, "..Hey man, lick the top of this..
Please do not try # 6. New hairstyles are always refreshing, but if you are wearing railroad tracks across your teeth, you might have one big filling after it痴 over.
HOW CAN CAPACITORS IMPROVE SOUND QUALITY?
They can't. Sound quality is not dependant upon the presence of large bulky 1 Farad capacitors. How many 1 Farad Capacitors do you think the Boston Pops, Aerosmith, or Snoop dog use in the recording studio?
IN A NUTSHELL.......
When Richard, our fearless inventor, became World renown for winning every competition under the sun, people began copying what he did. Soon, every 'serious' competitor had a 'stiffening' capacitor--not to be confused with the 'loosening' capacitor.
WHY?
In the late 80s, people began sticking out their tongue when dunking the basketball because Michael Jordan did. Did sticking out your tongue improve your dunking ability? Same here with adding a capacitor to your electrical system.
STILL A GLUTTON FOR MORE PUNISHMENT?
Here's the Original Cap Debate.
http://www.carsound.com/ubb/Archives...-1-000307.html
Phoenix Gold's marketing guru had just posted information on how their Powercore (basically the Alumapro CAP15 in a Phoenix shell) had both stabilized their voltage and improved the sound quality. Richard called him on it (all in another post) and the marketing geek was unable to quantify any of the conditions that resulted in the voltage being HELD at 14.2V and the 'improved' sound quality.
Please do not read every stinking post as valid. There are a lot of people that have had the efficacy of capacitors inbred to their minds, and were not (and still not) convinced in the futility of a 1 Farad storage device.
In a final note, Richard relayed a quote regarding battcaps ( www.battcap.net ) as, "..The audio industry is the only place i know of where you can publish specs that show your product is useless and still be able to sell them------and whats worse is that technically ignorant people will argue against the math!!!!!!!..............RC.." when referring to the product. This also relates to most digital readout capacitors, and I wish my Archie Bunker skills could have said it better myself.
Old 03-28-2014, 11:21 AM
on the other hand the Bentley says an alternator in an 88 is 90 amps. I am not sure what happens when you charge a 55 Amp-hour battery at C/.6
Rick
88 Cab
Old 03-28-2014, 11:25 AM
kdubb's Avatar
This is more difficult than I thought
I can only look back over the last 6 years with the Red Top. I had no problems with my alternator or electrical system during that time. Don't know if going with the Yellow Top will cause any issues.
Old 03-28-2014, 12:36 PM
I just wondered when Loren gave up on DMEs and became an expert on batteries and alternators.
Rick
88 Cab
Old 03-29-2014, 08:18 AM
"Wouldn’t this imply that the size of the lead acid battery in parallel with the load would have nothing to do with the magnitude of the current the alternator outputs if 13.5 is the charging Voltage?"
Not really! Basic electronics defines currents for parallel loads, i.e. different size batteries require
different charging currents which adds additional loads to an alternator besides all the others
system elements, e.g. FP & lights.
Remember, an alternator is a voltage source device, i.e. basically no current limiting, and NOT
a current source which limits current like the old generator system which had a limiting
current relay in the regulator. A battery is also a voltage source device with basically
no limit on its current output or current sinking (when charging) given the battery's cell sizes.
Also, the state of charge of a battery affects it's sinking current when charging,
i.e. very low battery can sink in many cases 70-80 amps when charging. That will damage
some alternators, i.e. '82/'83 911SC Valeo, when running the engine with all accessories.
Old 03-29-2014, 10:33 AM
Right on!
Old 03-29-2014, 10:49 AM
Tags
amp hours , battery , cca , optima
