in the pic with the rotor and cap, the cap does not look good. the post for #5? does not look good.
do not use a condensor with the MSD, or bosch. thats were i mounted mine in my 2.7.
What shape and how old are the spark wires? Even if they look good they could be breaking down from age. I just had a set of wires that looked perfect in my Mustang 5.0L but upon close inspection at night the wires looked like an electrical octopus laying over the engine! In the dark you could see them arcing and carrying spark over the surface of the rubber! Since you improved spark energy it could be that the wires simply can't contain the extra energy now.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
In my case they where also arcing over to engine tin in spots, I think that's what you really don't want happening. I also had arcing at the coil output to chassis.
Your saying that seeing the cables light up is not a problem, got it.
sal, i agree. i said in an earlier post craig bought a new set and his car ran worse. put the old ones back on and it ran better. new ones can be bad too.
west, do you make this crap up as you go along sounds like OP might have fixed it with the cap. if that does no fix it he needs to look into fuel/mixture and air leaks.
Here's my personal opinion about ignition:
You really only ever need just enough ignition energy to jump the spark gap. Often folks install way to strong ignition system for the needs of the engine. Not a good idea to over provision the ignition system as it causes a bunch of other issues. If you are not doing a turbo setup then a simple basic ignition is all you need. Even the factory changed from CDI after the 3.0L. The 84-89 3.2L uses very basic 12vdc old school coil and it's good for 7000RPMs. Not downing the after market CDI systems, I'm just pointing out that if the stock system can fire the plug and light the mixture you can't really improve things much. Furthermore, these systems that produce 2 sparks back to back are not that beneficial and only mask the real issue, 1 spark needs to do it every time!
"coil out put to chassis" I have seen this, but only with the HV wire to the distributor removed. If that happens otherwise there is a open, high resistance between the coil and the spark plug, or a gap to wide to jump. Or even to much pressure in the cylinder...FI. |
Inductive energy storage, the Kettering system, was always been a better system for plug firing if one could remove the limitations of mechanical power switching. With the Kettering system spark energy is stored in the coil PRIOR prior to firing. Whereas with CDI it takes time, however brief, to transfer energy from the storage capacitor to the coil primary. With CDI the coil inductance resists the transfer of energy into the coil primary. Once the solid state switching devices came along the "dwell" period could be raised as RPM rose, 99% even. Last edited by wwest; 04-09-2014 at 04:53 PM.. |
Dave |
Dual plugs are used to help light the flame front from both side of a Hemi cylinder at the very SAME time. When using dual plugs vs single plug in a Hemi cyl it allows you to not need so much ign advance to generate peak torque conditions (max cyl pressure). The down side of the hemi single plug is that the plug is offset far to one side of the cyl and this results in needing a lot more ign advance than with dual plug. The more ign advance results in fighting the piston on the up stroke before TDC. It's the trade off needed to achieve max torque. This is why the very same exact engine build with dual plug vs single plug, the dual plug will generate more torque on the dyno.
I have a 1973 2.7 with MFI. I drove it over 100,000 miles with points and stock CDI. I fine tuned the MFI very successfully in this time, but installing a good CDI system has made a HUGE DIFFERENCE in the way the engine runs, idles, revs and just plain has been a revelation. Multi spark works. A hotter spark works. You have to go into this with your eyes wide open. A more powerful CDI is not a plug and play deal. You need good ground, good +12 vdc power, good plug wires and a rotor and cap and wires that are up to the extra power. I have bench tested the Bosch, MSD, and a Daytona-Sensors CD-1. The aftermarket units put out 3 to 4 times the power that the Bosch does. If multi spark is so bad why do companies like BMW MB Porsche and others use it for starting and idling? Research it. One weak spark is not good enough for most old P cars. My opinion with lots of research and practical experience. Here is a link to my original post of my CDI experience Bosch 3 pin cdi replacement
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 Last edited by dicklague; 04-09-2014 at 06:14 PM.. |
Also for fuel ratios that tend to run on the rich side most of the time the high energy system tend to keep the plug a bit cleaner. Just don't expect miracles to happen by installing a better ignition if the old one works. It's the same with multi electrode plugs (BOSCH 4 or 2) they really don't help if the standard style plug can do the job. For engines with very high cyl pressures like Forced induction Turbo or high compression then I agree you need extra ignition to jump the spark gap (or close the gap down) as cyl pressures increase. But for most normally aspirated engines you don't need these high energy system. BTW - love your car. Is that a high compression 2.7L?
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 04-09-2014 at 06:34 PM.. |
The question becomes....how fast is the "swirl" the A/F mixture is in just prior to the spark, and then how fast is the flame front from that spark advancing vs the "swirl" speed. It should be pretty clear that if the second spark ignites an unignited portion of the mixture due to the "swirl" then a more rapid combustion of the overall cylinder "fill" will result. |
Upon firing the plug, how much, what %, of the previously stored energy is simply returned to the storage capacity? |
Hopefully ignition system energy of the spark and voltage of the spark are not being confused.
The ignition system spark voltage determines maximum total gaps (plug & cap/rotor) and cylinder pressures under which a spark can be produced. An ignition system producing a minimum of 250/300 primary volts is more than adequate. The ignition system energy is the energy available in the spark to fully ignite the fuel charge which is typically 30 milli-joules. Most OEM ignition systems produce 2-3 times this value.
Dave Last edited by mysocal911; 04-10-2014 at 05:28 AM.. |
Please try this
1 check spark plug lead order 2 check sparkplug lead order again 3 Then check that your order is correct to the rotation of the rotor 4 if not reverse the order, A posche will still run if you have it reversed 3 check plug leads in dizzy are ALL the way in 4 check that the coil lead all way in It could be as simple as that Ive done that, then rechecked and rechecked again only to realise the numbers in my head were wrong.
Wheels Last row 1977 3.0 930 260hp built, still reassembling Row 1998 996 MK1 3.4 296hp new daily driver |
did you change the coil from the Bosch CDI one to the Bosch Blue coil? or the MSD Blaster coil?
Tonight's ride
The ride home from work was up eventful. I had an even idle at stop lights and a smooth and quick run through the gears on the freeway. I run opposite the commute so getting above 70 mph was not a problem. The temp stayed normal which was not the case a couple of nights ago and the night before the backfire nightmare.
The new coil is an MSD blaster, recommended in Wayne's article #24. I copied the plug configuration from the cap I replaced. Since the car is a 77 but with just under 34,000 miles I don't think much has changed from the original. For now I am going to sit tight on the ignition, but this conversation has me thinking about new plug wires and possibly going pointless. I am learning a ton and thanks to all for the replies. |
