(sal, he knows, i think he is just stirring the pot....)
the points work great. but if you feel the need, get it running right before you make any mods.
so you think it was the cap?
@Orange911s
It was already mentioned several times by others in this thread and I thought it's worth pointing out again. If I had this car to work on the first thing I'd do is check fuel mixtures with my WideBand O2. You really need to be sure it's not running lean. No sense concentrating on ignition issues without verifying fuel first. If it's lean it can easily exhibit mis-fire behaviors. Do you know if fuel mixture is correct?
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
could be a plugged cat too. the ceramic can beat itself into a ball and depending on how it rolls up to the outlet, it can either plug it or pass gas through it's honeycomb.
- Inductive builds up energy over time in the actual coil windings and then releases this energy stored when the field collapses because voltage is removed from the primary winding. This results in a long release of energy but the voltage typically is not as high as CDI. The good thing about Inductive is that the spark lasts considerably longer than CDI but not as strong (less voltage). This style ignition does very well in cylinders that don't have extreme pressures. - CDI uses the coil as step transformer and NOT a holding device, coils can be used either way (CDI voltage stepping or Inductive energy holding) but they are different. In CDI the control module typically has large storage capacitors that charge to 200-500volts and then when commanded the capacitors release this voltage across the coil's primary winding. If the coil has a 100:1 wire ratio then the 500vdc gets stepped up to 500X100=50,000vdc at the output. This results in a very strong spark event compared to Inductive but it does not last as long. The spark is brighter hotter but not as prolonged in length. CDI works very well in Forced induction where cyl pressures are much higher and it difficult to jump the gap without sufficient voltage. Here the chances for not jumping the gap are more likely and is why CDI often fires multiple spark events back to back. In summary: Inductive ignition has 20,000-35,000 volts with spark durations in the 1000-2000micro seconds. CDI has 50,000+ volts with spark durations in the 400-600micro seconds. This site has a great detailed writeup about the 2 system and worth reading. Inductive Ignition | GILL
"When using dual plugs vs single plug in a Hemi cyl it allows you to not need so much ign advance to generate peak torque conditions (max cyl pressure)."
It's just all about avoiding detonation while achieving maximum torque! What the resulting timing turns out to be is of little value as long as the engine avoids detonation and achieves maximum torque. As an example, the Porsche 996 with its center spark plug runs advance timing greater than the air-cooled 911s. And the direct-injected 997 runs even greater timing advances than the 996. Furthermore, both the 996 and the 997 have higher CRs than the air-cooled 911s.
Dave |
The CDI system was used by Porsche for the fast spark rise time for fouled plugs which wasn't available in the '60s with inductive discharge systems. Now fast spark rise times can be achieved with today's advanced semiconductors resulting in all OEMs using inductive discharge systems.
Dave Last edited by mysocal911; 04-10-2014 at 05:52 AM.. |
Dave |
In the perfect world we would never want to start fuel burn before TDC but because fuel takes time to burn you have no choice but to fire the plug before TDC if you want to achieve max pressures at about 10-15 degrees past TDC. But the evil here is that firing the plug 30degrees before TDC actually fights the piston on the up stroke of the compression cycle and results in loss of torque. With a twin plug it helps light the flame fronts from 2 points in the cyl and the 2 flame fronts can more quickly (in less amount of time) burn all the fuel and this allows you to reduce ign adv. So if in the same engine you now only need 20 degrees adv this results in less fighting with the piston on the up stroke. One can not ignore detonation and some cyl designs are more prone than others. Bottom line is you CAN NOT allow detonation to take place and many times you MUST sacrifice power to avoid detonation. The points you make about the newer cars using more advance simply mean those engines are better designed to not detonate but more ign advance is not better. The holy grail would be to have ign at 0deg TDC and still achieve max torque but that's not possible because fuel takes time to burn. Further complicating this is that fuel tends to burn at a steady rate (amount of time) but as RPMs increase you run out of time and you require more and more ign advance as RPMs go up and this in turn fights with piston on up stroke and torque tends to drop off.
Battery is being overcharged and MSD is more sensitive to voltages above 15 volts than Bosch?
Porsche made the switch shortly after those became available. Still not certain that the relatively TINY COP can store anywhere near the energy to sustain a spark for long enough period vs those earlier coil modules wherein the "opposite plug" was also fired. |
I think it was the cap. I have not gotten to the timing yet.
I don't think it is a fuel issue. This all started with a day a couple of weeks ago where I got crank, but no start trying to get home from work. The car was running great before that. I am not as experienced as many of you guys, but I am comfortable swapping parts. I checked with the forum after that incident and the overwhelming push was to look at the CD box and coil. From there, Wayne's MSD upgrade article made sense. I started with the coil swap to the MSD and that did not solve the problem. I then swapped the OEM perma-tune box for the MSD and it was running fine, with a few misses. This escalated into the backfire situation that started this thread a few days ago. I will put some miles on over the next few days and see how it goes, but so far so good. |
I read the GILL report. They make inductive igntions. They make NO CDI ignitions. So what do you think they are going to say?
Some of what they said is misleading at best and possibly wrong. For example, a direct quote: "Typically a capacitive discharge system will deliver a maximum of 10 millijoules of energy compared to an inductive ignition system delivering more like 50 millijoules of energy and potentially in excess of 100 millijoules. This large difference in supplied energies will mean an inductive system can provide spark duration of 2000 microseconds or more in a single spark, compared to 600 microseconds for a capacitive system." The Daytona-Sensors CD-1 that I have in my 2.7l MFI 1973 puts out 135 mJ [millijoules] of spark energy, NOT 10! Most MSD models put out in the 75 to 85 mJ range. So once I read that and realized that GILL makes and sells ONLY inductive ignition systems, I can't put any credibility to what they wrote in this report. I know inductive systems to a great job but stick to the facts GILL! I do know that a properly installed high quality CDI system in the form of the Daytona-Sensors CD-1 has made a great difference in my 911. It comes with a matching coil so that your are sure the system will perform to its maximum. I have to comment that some posters on this thread rebuild Bosch CDIs as a business and they have been critical in the past of anything but the original Bosch CDI being used in cars that are so equipped. Reading through posts here there is a lot of history of problems with aftermarket CDI whether caused by faulty installation, other components not being upgraded or just plain failure of components. I am convinced that if you choose a good aftermarket CDI, install it properly, and make sure your cap, rotor, and wires are up to the task, you are going to get increased performance out of your early carb of MFI 911.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 Last edited by dicklague; 04-10-2014 at 10:36 AM.. |
Dick,
No question about it, CDI system works as does a good electronic inductive system. Either would be a good choice to replace the older points. BTW - I ran a pro MSD setup in my 84 3.2L and it worked just fine but it did not make any difference compared to the stock ignition so I took it out and went back to the simple stock setup. Used MSD 6200 controller with MSD 8250 coil this is the pro version from MSD same used in NASCAR. Nice unit did the job well but had no effect on performance or running over the stock setup. Quote:
Distributorless COP INDUCTIVE ignitions... |
I think what we conclude here is that the older points CDI could be improved. And we have 2 choices: electronic triggered CDI or inductive and either would be an improvement.
But the CDI is somewhat more complex and prone to failure over time, it simply has more components like the big capacitors that don't stay in spec over time. While the inductive systems have darlington transistors that are extremely reliable. Here's what Motec has to say: MoTeC > About Ignition Systems > Overview They don't sell any ignition products but do sell top self ECUs.
