Where is this leaking?
Anybody got any ideas?
Old 04-13-2014, 03:05 PM
non-whiner
mreid's Avatar
Man those are some crapy pictures. I can't even tell what side of the engine that is (driver side maybe? Looks like the oil output line on the far left side of the first picture?). Could be any number of things. Is it only on cylinders 1 and 2?
"Too much is just enough."
Old 04-13-2014, 03:12 PM
Reiver
Reiver's Avatar
clean it all off....short drive...locate source. Too much oil and too manny possible sources.
Old 04-13-2014, 05:48 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1
'85 Carrera Targa
PCA/POC
Old 04-13-2014, 05:51 PM
The overall pattern suggest a classic oil overfill. The perfect alibi to spend a crap load of cash on unessasary upgrades.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 04-13-2014, 10:47 PM
Bill Douglas's Avatar
It's a lot of oil, so I'm with Shane on this.
If it was less I would be concerned it was broken headstuds, which just makes it seep oil from all the wrong places. Well, it did on mine.
Old 04-14-2014, 12:20 AM
kodioneill's Avatar
Looks like head stud issues to me.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 04-14-2014, 04:34 AM
Being a 77, they are pulled and wont torque but you can try.
Bruce
Old 04-14-2014, 07:15 AM
I hope its not stud issues, this engine was rebuilt shortly before I bought it, Timecerts, hydraulic tensioners, all the upgrades. thanks for the feedback! this sure is a great site, great people!
Old 04-14-2014, 09:12 AM
Far too premature to say head-studs right now. Clean it up, and then see what happens.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 04-14-2014, 09:35 AM
Got any suggestions on how to clean it up, the car is in the middle of spring plate bushing replacement in my garage so power washing it would be a little complicated.
Old 04-14-2014, 10:36 AM
Put a bunch of newspapers under the car. Liberally douse engine bottom with Gunk(original formula). Let sit for about 10 or 15 minutes. Then, take a small brush(es), some rags, and a squirt bottle of water. Scrub and rinse for what feels like forever. Then you'll have all the oil off the engine.
Old 04-14-2014, 12:58 PM
head to cylinders leaks from the looks of it.
206 637 4071
Old 04-14-2014, 01:05 PM
Not crazy about Gunk too aggressive on paint and alloy. Try Mineral spirits and follow up with Dawn.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 04-14-2014, 05:10 PM
I think that you could tell if it was an overfill by looking at the top half of the engine, I recommend doing a partial drop and removing the intake and cowl, then you can clean up the mess if that's what you find, otherwise you should be able to tell if it is leaking from somewhere else. If you don't see a mess of oil on the top, then you can be pretty sure it's coming from between the heads and cylinders.
Old 04-14-2014, 07:03 PM
