nene's Avatar
Why unplugging the 02 sensor makes my 3.2 run smoother..
I replaced my 02 sensor a few months ago and recently noticed that if unplugged, the car ran smoother in general, no flat spots upon revving. Just a few notes, I did check all vaccum lines, adjusted valves, new sparkplug cables and adjusted base idle. Maybe running rich, although it doesn't smell like it.
Thoughts?
Serge
Old 04-14-2014, 11:19 AM
LJ851's Avatar
It goes into default mode which is richer and generally runs better since these cars were pretty lean originally.
Old 04-14-2014, 11:25 AM
E Sully's Avatar
Does the idle drop when you remove the oil cap? If not, you may still have a vacuum leak.
Ed
1973.5 T
Old 04-14-2014, 11:26 AM
RETIRED
Joe Bob's Avatar
Or the O2 sensor is dead.
2012 ML350 3.0 Turbo Diesel
Old 04-14-2014, 11:30 AM
Just a guess since I am not the engineer who wrote that software.
It is because the feedback loop is broken, and the ECU is no longer trying to adjust the mixture. It is working off a set fuel map and it runs better.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-14-2014, 11:36 AM
nene's Avatar
That for your the replies:
Yes the idle drops when removing oil tank cap. The original 02 had the same side-effects as the new one, that's why I changed it.
Generally as the engine warms up, the car runs good with the sensor connected, but does run better without it.
Serge
Old 04-14-2014, 01:07 PM
abit off center
cgarr's Avatar
I noticed the same thing with mine until the sensor got good and hot.
______________________
Craig
G2Performance
Old 04-14-2014, 01:25 PM
shahram's Avatar
What is your idle RPM with O2 sensor plugged and unplugged?
Old 04-14-2014, 01:28 PM
nene's Avatar
The idle remains the same under both circumstances.
Old 04-14-2014, 02:27 PM
