Why unplugging the 02 sensor makes my 3.2 run smoother..
I replaced my 02 sensor a few months ago and recently noticed that if unplugged, the car ran smoother in general, no flat spots upon revving. Just a few notes, I did check all vaccum lines, adjusted valves, new sparkplug cables and adjusted base idle. Maybe running rich, although it doesn't smell like it.
Thoughts? Serge |
It goes into default mode which is richer and generally runs better since these cars were pretty lean originally.
Does the idle drop when you remove the oil cap? If not, you may still have a vacuum leak.
Ed 1973.5 T |
RETIRED
Or the O2 sensor is dead.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Just a guess since I am not the engineer who wrote that software.
It is because the feedback loop is broken, and the ECU is no longer trying to adjust the mixture. It is working off a set fuel map and it runs better.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
That for your the replies:
Yes the idle drops when removing oil tank cap. The original 02 had the same side-effects as the new one, that's why I changed it. Generally as the engine warms up, the car runs good with the sensor connected, but does run better without it. Serge |
abit off center
I noticed the same thing with mine until the sensor got good and hot.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
What is your idle RPM with O2 sensor plugged and unplugged?
The idle remains the same under both circumstances.
