Driver's License Owner
The Watson's Avatar
Wanted to get as much out of the way before engine goes back in. Rear suspension completely rebuilt and upgraded. Brakes rebuilt. New sound pad, fuel lines, clutch cable, etc. Also rebuilt shifter and hand brake.
Thanks -- Chuck
1977 911S Backdate Street/Track, 1970 911T, '70 Triumph GT6+ Vintage Racer Project, '60 MGA Restomod/tribute, Cayman R, 1967 Moto Guzzi V700
Old 09-03-2020, 01:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
(man/dude)
Jonny042's Avatar
Looking great! Thanks for the update.
I'm sure the anticipation of seeing it on its wheels is killing you!
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 09-04-2020, 07:53 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
The Watson's Avatar
Yes! I'm so tired of seeing the rear end hiked up!
Thanks -- Chuck
Old 09-04-2020, 07:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
70SWT's Avatar
Originally Posted by Discseven View Post
Knew you weren't married at this point. Congrats to you Chuck! Nice work on car(zzzz)!
Yep, that is the kind of progress you can make when unfettered by wife and kids. Good looking car all around
Old 09-04-2020, 12:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
The Watson's Avatar
Today was engine install day! Four post lift and hydraulic lift table made it safe and fairly uneventful. About 3 hours to get it bolted in by myself and as a first timer. Had to take off rear bumper and will have to file out clearance for tailpipes a bit before reinstall. All in all a very satisfying milestone.
Old 09-26-2020, 02:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
You need to put the fuchs on the motorcycle in the back round. That would be sick!!
Old 09-26-2020, 04:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
The Watson's Avatar
Surprised no one has tried that yet.
Old 09-26-2020, 06:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
Nice to see another 77’ owner. I am a new one and just took my first long trip of 500 miles. It’s a relatively low mile car that wasn’t used much so I was expected that after some stretching of the legs some things would pop. Well I developed an oil leak from a hose at a connection between.
As a relatively new owner I need some clarification as to what the hose name is. Leak is coming form the connection point and not the rubber hose itself.
It is the hose just in front of the engine oil cooler.
Can somebody identify the proper name of the hose. To fix the leak does it require replacement of the entire hose or just the seal between the connection points? Is the seal formed by a crush washer, o ring, flat faced seal. Picture with this points has the connection and hose in question circled, relative to some of known parts on the right side of the car. I appreciate any and all help
Old 09-26-2020, 07:04 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
The Watson's Avatar
Oil cooler kit install time! Fender mounted from BAT/Setrab. Nice quality. One day start to finish.
Also, I sold an XKE project and a 356C race car. Used some of the proceeds on this!
Old 11-09-2020, 10:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
The Watson's Avatar
A few updates
Been working on a few projects at the same time as parts arrive sporadically.
Installing heat/sound insulation before new carpet.
Rebuild of entire front suspension and brakes in progress.
Making my own custom decklid, underway.
Thanks -- Chuck
Old 05-02-2021, 07:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
Nice build...
Old 05-03-2021, 07:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
The Watson's Avatar
Longer hardware from Belmetric arrived, so I was able to complete the decklid cover. I also purchased stainless mesh to go underneath if I decide it’s necessary. Overall, happy with it except for some minor mistakes.
Old 05-11-2021, 08:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
al lkosmal's Avatar
Nice work. Looks great and well done.
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 05-11-2021, 09:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
Fantastic.
I've been sketching up something similar for the past couple of years, with the stainless mesh to be domed at each hole. My design just on graph paper has the holes all the same size for this reason.
Flat is cool (image in link below), and a lot less prone to damage than domes I assume.
Post #254 by mrm930
911R engine lid grill material
Old 05-12-2021, 04:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
The Watson's Avatar
Fantastic.
Post #254 by mrm930
Yes, I saw that post and like it a lot. My intention was to also shape the mesh but it is woven rather than welded so it might not work. It’s less obvious to find uniform securing points on the underside as well, so for now I’m punting on the mesh.
Old 05-12-2021, 05:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
Everything looks stunning so far nice job. What brand of sound/insulation did you use
it looks great.
Old 05-12-2021, 05:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
The Watson's Avatar
it looks great.
Frosty,
Thank you. Insulation is from Rockville Audio. Great product - wear gloves to not slice your fingers on foil. Good prices. They also have it in black, which is probably a good move under dark carpet.
https://www.rockvilleaudio.com/rm36-s/
Thanks -- Chuck
Old 05-12-2021, 06:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
Thanks Chuck, I’m just getting ready to attempt an RS carpet install and was going over your thread you’ve got some skills. How many rolls did you use for your car.
Old 05-12-2021, 06:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
The Watson's Avatar
One roll covered what you see in these pics. Everything but the front floorboards. As that area is susceptible to water collection I thought I'd do something removable up there.
Thanks -- Chuck
Old 05-12-2021, 06:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
Thanks Chuck, and thanks for the Link I see it’s on for half price I’m placing my order.
Old 05-12-2021, 07:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
Tags
1977 77 r
