Where is this oil coming from?
A couple questions. Is this the starter that's in the below picture? And also some thoughts on where the oil may be coming from as there's A LOT of dried (and some fresh) oil caked on it? Is there some kind of oil line that runs above it? It seems pretty isolated to that area.
2014 Panamera Turbo Executive 1982 911SC Targa - Guards Red 1983 DeLorean (Sold) 2001 996TT - Lapis Blue (Sold) 1995 993 C2 - Grand Prix White (RIP) |
Yes, startet in the pics middle.
Oil you see seems to me to be rather the spray from an other area. Check "triangle of death" around breather. |
This is the first I've heard of the "triangle of death". I'll do some research on it thanks.
Its the area upside behind the intake, where 3 culprits sit, that can leak all three.
But mostly its the breather cover gasket. |
Does not look too bad, imo. I agree on the holy trinity. It is an engine out job, but I imagine that somebody will differ.
Member 911 Anonymous
Remove the air box and stick a hand mirror and look for oil residue. The triangle would be the Breather Gasket/and or the hose, Thermos stat and oil light sensor gaskets.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Oil leak.
And here's a pic for the 3.2 motors:
![]() Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Oil leak.
High probability that the engine oil thermostat O rings are leaking. Looks just like my car oil leak repair solution.
Assuming you take off all that stuff for the visual inspection, can the necessary repairs be made without removing the engine?
Do you need to remove all the CIS stuff also?
No just the air cleaner,you could also give the area a good clean then it will be easier to pinpoint the leak after running the engine for a while.
Is there oil around perimeter (bellhousing) where the motor bolts to the gearbox?if yes it could your rear main seal .
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Fleabit peanut monkey
First off, as noted, your oil residue ain't that bad. DRACO says remove the airbox, which is difficult to R&R. I would skip that for now, but go get a couple of decent mirrors. I like girly girl mirrors with some length on the handle and a decent size mirror face for looking behind my 81. Plus they help me look beautiful in my non-wrenching moments. The auto parts store mirror on a telescope stick are great for small areas but you need a big screen. Once a bigger mirror is back there it can be moved enough to capture a decent view. Don't skimp on the lighting. I would maybe pull the bellows off between the air sensor and throttle body if a side angle is not providing a clear view. Another option is to pull the two big fat bolts holding your engine in place in the rear corners of the engine compartment with a floor jack under the engine. You can drop the engine about 4 inches without issue to increase you visual penetration. Also, to clean things a bit without going nuts you can spray simple green around the triangle and blow the loosened up grunge off with an air hose. A garden hose would work ok but then you have the same risk issues as with power washing. I.e., possible water in electrical connections. Anyhoo - if you find your leak and you deem it worthy, make you decision as to how much pain you can endure. If you are fortunate and you are a small boned, 130 pounder with feminine hands, you hit the jackpot. You may not have to remove a bunch of stuff to gain access. If you have meat hooks for hands, pull some stuff off and leave a little time. Airbox removal provides you lovely access. It sucks time and is like a puzzle to re-install. Very do-able, though. Also gives you a chance to examine closely for air leak issues.
1981 911SC Targa |
On your SC (CIS) you'll have best luck in doing a partial engine drop to gain as much room back there as possible.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Good luck with your oil leak search and repair.. Thanks Gerry for the triangle of death picture. Any modification/ change out recommended to that area while you are in there. Engine out.
==>> 911SC oil leakage from top - easy acess? <<==
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
