Brew Master
cabmandone's Avatar
You can see the part number without removing the sending unit. Takes longer to open the engine lid...
JR
Thanks! I'll take a look later and let everyone here know what I find regarding temp of lines and numbers on sending unit.
Fan belt has been appropriately tightened.
Thanks again everyone.
Old 05-11-2014, 07:40 AM
al lkosmal's Avatar
+1...check that the sending unit and oil temp gauge are a match. This is common reason for incorrect temp readings.
regards,
Al
RGruppe #669
http://www.x-faktory.com/
Old 05-11-2014, 08:06 AM
I better check mine out too. Good thread...
Sent from my RM-877_nam_att_205 using Tapatalk
Old 05-11-2014, 08:35 AM
Brew Master
cabmandone's Avatar
UPDATE:
Took it out, drove it easy to let it get warmed up then drove it Temp gauge went up to about the range shown on in the first post. Fan belt was tightened, ambient is about 78 F. Put my long Brewing thermometer that goes up to 220 in the oil tank (how much do I love this car?). Got to 180 and stopped. I couldn't see a number on the temp sending unit but since I want to get a headlight relay kit from the sponsor, I'll just order the temp sending unit with that.
Old 05-11-2014, 10:21 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 too high let us know f you have crushed lines. I would get a IR temperature reader and check the actual temps at the thermostat at the passenger side rear wheel well, the hotter one is coming from the engine.
Mine goes right below that hash mark in the summer. in heavy stop and go traffic, as long as you stay in between the two middle hash marks you are good. Normally at full operating temp, mine will stay at 1/8 inch about the first hash aka 8 o Clock.
What weight of oil are you using?
'85 Carrera Targa
PCA/POC
Old 05-11-2014, 10:38 AM
Originally Posted by cabmando View Post
Temp gauge went up to about the range shown on in the first post.... Put my long Brewing thermometer that goes up to 220 in the oil tank ... Got to 180 and stopped.
You have got to have the wrong sending unit. Have a look at the far left side of yout gauge and see what the highest calibration number is. 150C/300F or 170C/340F, etc and order the correct sending unit.
JR
Old 05-11-2014, 12:07 PM
non-whiner
mreid's Avatar
Looks like you found your problem. Congrats!
"Too much is just enough."
Old 05-11-2014, 12:14 PM
Brew Master
cabmandone's Avatar
JR
Is there a 60C/180C option? Those are the numbers I can see on the gauge face to the far left of the lines.
Here's the one I find on the P.P. site http://www.pelicanparts.com/catalog/SuperCat/0806/POR_0806_ELSENS_pg2.htm#item6
I don't see any other option for my car and this is the 85 gauge.
Old 05-11-2014, 05:46 PM
I'm guessing that you have gauge number 911 641 923 00. You probably need sender 911 606 112 00. I'd still take a look at the one you have, first. With a flashlight and a mirror (wrost case, may not be needed) you should be able to read the part number. It's stamped on the sending unit.
JR
Old 05-12-2014, 04:27 AM
Eva
911SauCy's Avatar
This thread hurts...
Fully solidifies that my SC is running to dang hot.
Hopefully, the new t-stat will remedy this.
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 05-12-2014, 05:29 AM
Better to deal with it now and just resolve it.
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 05-12-2014, 05:46 AM
TheSt|G's Avatar
Originally Posted by gamin View Post
Gauge overlays are available from newvintageusa.com and are easy to install yourself. It is useful to purchase an IR thermometer hand held. Can check temps at various points at various times. They are inexpensive. Amazon. Your temp indication is high.
Thanks for this, added to the list.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 05-12-2014, 06:44 AM
Brew Master
cabmandone's Avatar
JR
Just got a flashlight in there and it's a 150 C thermostat. Based on what I found on the gauge, it's the wrong thermostat for the gauge. I'll be ordering and updating with pics as soon as the new one is installed.
Old 05-12-2014, 07:20 AM
cabmando -- Have you checked the temp of your front oil cooler lines when the engine's hot (i.e. simply checked to confirm that the front oil cooler lines do get hot?) Sounds like the wrong sensor's the root cause of your problem, but while you're getting this together, also important to confirm that the thermostat that lets hot oil flow to the front cooler is, in fact, working.
Old 05-12-2014, 08:30 AM
Brew Master
cabmandone's Avatar
Yes, I did the touch test after the test drive with the fan belt tightened. The lines were hot. I didn't put my IR on them to check temp but I didn't want my hand on them long. That really doesn't mean much though as my wife says I have "sissy hands" to many times freezing my fingertips removing AC gauges when I did HVAC I suppose.
Old 05-12-2014, 09:54 AM
If the temp sender is brass, then its early, pre 77 with a 901#. If its chrome covered, its post 77 with a 911 #
Bruce
Old 05-12-2014, 10:12 AM
So, my gauge showed high... At 10 o'clock, while idling in the garage with the a/c on. The front oil cooler lines never got hot. The oil level gauge did eventually rise to near the top, though. So the engine really did at least get warmer. I am wondering if the thermostat is not working, and/or my server is inaccurate. Where can I find the sender? Is there an article I refer to? Thanks all
Old 05-12-2014, 07:31 PM
Ugh, I was getting the hours on the wrong side, on the drivers side. Oy. Warning the car up now to see how it behaves...
Old 05-12-2014, 07:39 PM
polizei's Avatar
Fwiw, I had the same problem. Gauge was reading high relative to infrared thermometer readings on the engine, oil lines near engine and auxiliary oil cooler lines. I sent my gauge to north Hollywood speedometer. They replaced the oil temp movement and provided a matching new sender for $165 shipped. Went from reading 230F and panic attacks to 185F.
Andy - 1987 911 Carrera Coupe
Old 05-12-2014, 08:07 PM
Sorry for the bad autocorrecting. I was feeling the hoses ion the wrong side of the car. I let the car get hit just now, the temp went to just shy of 10:00, and settled back a bit. I felt the hoses on the PASSENGER side (sigh) and they were hot.
Oddly though, earlier in the day, the engine got a lot hotter. It was warmer out then, but not by much. I am still uncomfortable with how hot it got before I shut it off. I will check the sender and gauge combination tomorrow.
Old 05-12-2014, 08:20 PM
