If you only lowered it to European specs height, why do you need a bump steer kit?
The Cap'n |
Are both front and rear tires new? Different tires front and rear can cause very erratic symptoms.
I agree with the Cap'n but doubt your washers would cause the symptoms you're talking about.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) Last edited by moneymanager; 05-21-2014 at 06:00 PM.. |
When you went back to the shop that did the corner balance and alignment what did they say?? Hopefully you went to a shop that is very experienced with the 911 suspension.
Also, one of the best bits of advice I picked up on this forum is to not set the tire pressure per the door jam spec of 29/36. I have the same setup as you described and I run 34/36 and the handling is much better. Good luck!
crude rudy '84 cab '14 ZX-14R |
Go-Kart Mozart
Agree with the others that a touch (1/32") of rear toe in could help settle the rear of the car. New tires may need a couple hundred miles to wear in. Which brand tires?
Nice lookng ride. Prussian Blue is the best blue, but I'm biased. You cars looks very much like mine all the way down to the euro tail lamps. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
Member 911 Anonymous
+1, bascially more toe in rear vs front. Mine is set zero front and 1/32 each side rear 90MPH+ no issues, but I do have a tail front lip that also helps.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
86FlatSix
I had the same experience right after I lowered mine below euro height where the car feels like it literally floats or similar to hydroplaning to the other lane until I had the alignment set correctly. Runs tight now even without corner balance.
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
Max Sluiter
FWIW my car handles way better now that I removed the sway bars. Rear sway bar bushings were shot and that might have something to do with it, but feels much more stable now. Doesn't want to swap ends in the tire-warming swerve test.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Okay, some progress. I measured the front toe this morning and guess what? Toed out 1/4 inch reset to 1/8" toe in much better but still not right. I'll have to go to another shop for alignment check because the other corners could be off.
Thanks for all your suggestions.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
This when I had my 85 Carrera was a huge help. If your running the factory rubber front spoiler without a tali, at high sppeds thhe car is not very stable(at least from my experience). best would be to remove the front rubber spoiler or add a tail.
Rey....77 930 "the Mistress" |
You have your toe in setting backwards, zero toe in front, 1/16" toe in rear.
Lots of info on the web on rear toe independent suspension settings |
Yet another "you need toe in in the rear" opinion to add to the bunch ...
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
