The amount of drop, inlet temperature vs outflow, depends greatly on blower speed setting. If you had the blower cranked all the way up 30F differential is a respectable #.
The only valid way to measure the vent them is to roll up the windows and go for a drive. Sitting in my garage my AC never gets real cold. Get out in real world driving situations and measure the vent temp. Fan running at MAX, you should get 40 to 50 degrees even in 100 degrees heat.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
When we charge & test vehicle systems, the doors are closed, windows are up, the heater off, the fresh air vents closed, otherwise you will never know the final performance or delta.
On the other side of the industry, HVAC for homes, commercial or industry... can you imagine a tech trying to charge by P&T and all the windows are open? lmao, he will be there for days! |
Banned
Banned
With the windows/doors open the system inlet airflow will not vary with time, providing a temperature reference CONSTANT throughout the charging procedure. With the car closed up the temperature "reference" will be declining, possibly rapidly, and thus only the high side pressure will be affected by OAT. It is my understanding that in order to properly charge using pressures, low side pressure, the TXV must be WIDE open... Enlighten me..? |
I think there may be confusion about charging by weight, and charging by P & T. On most a/c service jobs, the system is factory defined and the charge amount is specified. An automatic machine evacuates and charges by weight. This goes faster with max heat loading, thus doors/windows open. When charging by P & T, the conditions simulating actual use allow evaluation of pressures at outside ambient temperatures, and measurement of applicable vent temps.
At least that is my understanding. Dave |
I was also under the impression that doors/ windows open was the best way to load the evaporator/ TXV and get the correct P/T for checking. Of course, as I said, I am a novice at AC charging. What are the correct high side/ low side pressures for 100F ambient?
A chart with this data was with my gauges: ![]() I guess I am lucky I ran out of R134 before getting to 300#!!! Lastly, what is the drier sightglass supposed to look like? Full or not? I will check pressures again tonight and run it with the windows closed to see what temps I get to. |
Look, NOBODY, besides you know who, drives around with windows down and the AC on, an tries to charge a system based on P&T or estimated volume with windows down. 100F, R134a, in a perfect world with a stock 911, go for 276 max. R12 is 240 |
Banned
Actually, "you know who" has revealed in another current a/c thread that he does not do any a/c charging, period - pays shops for that service and to do simple tasks like r134a conversions. Whoda thunk it based on his years of all-knowing, a/c pontification!
Well, you knew that.
And Walmart is having a sale on RedDotTrinarySwitches |
Fleabit peanut monkey
https://www.youtube.com/watch?v=80jSH8VQZms
1981 911SC Targa Last edited by Bob Kontak; 08-18-2014 at 06:52 PM.. |
Banned
^^^ Bob, is it possible that "Scotty Kilmer" is wwest's pseudonym?
I have not absorbed this thread deeply enough because I am still reeling from the R/D dent mishap.
1981 911SC Targa |
I decided to start over and had the system evacuated. It has been on the vacuum pump since last night and I plan to recharge after work. It is expected to be 85-90F and 60% humiduty this eveing. What should I target for pressures and vent temps?
Thanks in advance. P |
Banned
At first, I thought he was a clever troll, but then found out he actually believes the fertilizer he's shoveling. Which makes it even more sad. Well, that and the weird conditions he sets up for what constitutes a functional aircooled AC system. Change the interior color??? Tint the windows??? 75 degrees is plenty cool enough??? Seriously? If you take the money you spend changing the interior color and tinting the windows, you can buy a whole pile of stuff from Griff, a nice vacuum pump, and a set of gauges. And do better than 75 degrees, LOL. And not ruin the value of your classic sports car by pimpin' it and changing the color of the interior from the one on the sticker. In addition, the fact that you would have a working AC system means that the value of your car goes UP, because now you could sell to a wider market. By my estimate, buying stuff from Griff could return 70 cents on the dollar, which is a heck of a lot better than just about any other modification you can do. |
