![]() ![]() ![]() "...75F would be perfectly suitable..." Provided the factory A/C system could get "there", but alas, it cannot, not even with Griffiths FULL aftermarket A/C enhancement product set. The best we can hope for is to get enough cooling airflow from the vents as to have localized, regional comfort. Or is Griffith now offering a window tint kit to overcome the greenhouse glass sunlight radiant heating effects?? The human comfort equation is not just about local OAT. Last edited by wwest; 08-26-2014 at 10:12 AM.. |
Willy, I'm about tired now of your mouth. Do you have a good health insurance policy? |
fyi I went with the full boat minus the rear condenser....try it you might like it..
Rey....77 930 "the Mistress" |
How about an answer to my question instead of sniping? Please.
I do not think I pulled a good vacuum before and surely didn't charge properly. So, I have now evacuated the system, vacuumed and am ready for a recharge. What should I target? Let's assume 85-90F ambient (60+% humidity if it matters). :P |
Banned
Banned
Griff, you and me both. I'm not sure if I've ever come in contact with someone who has so little real world experience with a subject but comments as if he is God's gift to it (and keeps his lines of nonsense going year after year). I guess doing that is some kind of lame cry for help?
Banned
The point I was trying to make is that you can get the cabin atmosphere as cool as you like, but you're still subject to the sun's radiant HEAT, even sunburn, absent adding good window tint. And it isn't just you that's adversely affected by the suns heating rays, HEAT your interior surround and now add that to your comfort equation.
Notice how everyone here uses vent temperature as a comfort reference..... that's pure BS. The focus should be in the cabin's overall temperature, inclusive of MRT. So yes, the Griffiths system, fully implemented, can deliver TONS of cooling airflow. And if the constant flow of DRY, cooling airflow to your face and upper body makes you comfortable, fine. Meanwhile I'll go for more of an overall method of addressing the human comfort equation, cabin atmosphere temperature AND MRT. |
Think about this: Once the cabin atmosphere's temperature reaches, or declines to nearby your, and your wife's, passenger's, etc, comfort level, wouldn't it be nice to reverse the airflow, outflow from both the footwell areas, no more seriously discomforting DRY, CHILLING airflow to the face and upper body.
What would it be like if that CHILLING airflow were routed out through the footwell vents? You could even, if need be, turn up the cooling level enough to address the overall cabin comfort level and still not be discomforted. |
Or do you mean you must keep the system outflow at a seriously discomforting level, CHILLING level, in order to keep the cabin's average temperature in a reasonable comfort zone? |
I was not denigrating your system, only that it fails to address the elephant the room, MRT, Mean Radiant Temperature, the adverse effects of sunlight through the glass. PS: IMO you would do well by recommending window tint as a way to address MRT, a reasonable adjunct to your product set. Last edited by wwest; 08-26-2014 at 10:13 PM.. |
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Crystalline Automotive Films - Clear automotive window film for cars, trucks - Crystalline - 3M US Looks as if it could even be applied to windows without changing appearance.....value. |
Banned
Well, he's either full of crap, or a liar. At other times, he has said he doesn't question that your stuff works, but then says crap like the above. In any case, It doesn't take that long to get the cabin comfortable. And in some cases, I have to dial the AC back, if I'm not wearing slacks and a tie. The stock(ish) system has plenty of condensing capacity for dry desert 100-degree days. |
Banned
Absolutely spot on, Eric. It's also sad how he will go to such ridiculous lengths to attempt to prove a point which isn't there. His latest nonsense about overall cabin temperature rendering vent temperatures unimportant, and his foolish commentary attempting to cast a negative light on the low vent temps I've (and other,s too)achieved ("that's too cold - you must be terribly uncomfortable") really exemplify just how desperate and silly he has become (nothing new, though, been displaying these qualities for quite some time).
Banned
Banned
Cabin temps are a result of the vent temps, and without low vent temps, you aren't going to get cabin temps down. I thought everyone understood this. The lack of wwest's comprehension is stunning, even now. If you have the sun shining on you, directly, then really cool air from the vents is very nice. But wwest thinks mid-70s is "comfortable". ANd thinks everyone else is "comfortable" at that temp too, and cannot grasp that some of us want the cabin to be closer to, ohhh, 68-70 degrees. To the OP - this isn't about sniping - it's about archived info. Some other poor sap might actually take wwest's suggestions seriously, which is why he so thoroughly screws up every AC thread - so he can peddle his foolish "solution" to 911 AC. Just a casual stroll around his posts will show a pattern of usurping threads to pointedly NOT answer the technical question, but to push his brand of AC "repair". He's done it to you here, as well. |
Banned
wwest whole argument against the usefulness of low vent temperatures in a 911 is really puzzling. Along with what you note, the lower the vent temps, the quicker the entire cabin temperature is reduced (not just the air blowing on one's face and chest), and if the environment becomes too cold for comfort, well heeelllooooooo, there is this device on board called an adjustable thermostat. For me, this is not based on reading, but on actually experiencing very cold vent temperatures, on extremely humid, hot and sunny days, in an air cooled 911. Maybe wwest actually knows better and his latest line of tripe is simply an example of Bob's noted "chain yanking for sport". I struggle with wanting to take the bait, but like you said here and elsewhere, his information is so flawed that it is a disservice to others to let it slide by unchecked. Last edited by Ronnie's.930; 08-27-2014 at 09:24 AM.. |
