Flyin' blind
Today's f*****g noob moment…. need help obviously
I will chalk this up to a learning moment…..
I am replacing the front shock inserts in my '89 coupe. My SS brakelines are too short to allow the strut to pivot out of the wheel well enough to get the insert out….. No problem, I'll just detach the line where it connects to the hard line and cap that one so I don't lose all the fluid my mechanic just flushed through in April….. you see where this is going right? After 30 minutes of trying many half-assed fixes for the leaking fluid I am now bled dry. Damn It! I really didn't want to tackle my first flush this year. Now to the question.. How do I release the proximal end the SS line from the clip that holds it against the body? Thanks in advance…. with head held down in shame….. Thom
Thom 89 Coupe |
Your over thinking " just take the line off do the repair and bleed the system
It's not going to take you long . |
In the future if you put a bar between the drivers seat and brake pedal depressing the pedal the fluid will not leak out.
89 930 Cab Black 11 Cayenne |
Flyin' blind
Thanks Mike! I read that somewhere else and forgot that simple trick. Clearly I'm still learning...
Thom 89 Coupe |
83 911 Production Cab #10
[QUOTE=livetopedal;8092641... Clearly I'm still learning...[/QUOTE]
C'est la vie... Next year you will be laughing about this one ![]() ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Flyin' blind
Halfway into my first Rye Manhattan and I'm already laughing…...
Thom 89 Coupe |
Member 911 Anonymous
+1 what they wrote, just take a breathe, you will be a DIY pro soon
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
take the horseshoe clip off and feed the metal line through the tab and you don't have to disconnect the hose.
Flyin' blind
THAT'S what I needed! Thanks John!
Thom 89 Coupe |
Spend $50 on a Motive Power Bleeder...the one with the hand pump on top. One of those "best $$ I ever spent" kinda tools. Turns brake fluid flush/bleeding an easy, satisfying one-man job. John.
1984-911 M491
^ +1
1984-911 TLC......SOLD |
i modified my motive bottle to be just a pressure pot. just air, no fluid. drilled a hole up top and installed a steel tire valve. a quick fill from the air compressor beats all the hand pumping.
walkers that is briliiant ... just brilliant... thanks another great pp tip
Flyin' blind
Well, F/R shocks, axle assemblies, many $$$ in tools and I have blown my first year budget… still lots on my short list too.
Thom 89 Coupe |
Home-made power bleeder.......
I stopped using my Motive power bleeder after I made this set-up 15 years ago and comes very handy with the G-50 clutch bleeding job. The red cap mounts on the brake fluid reservoir and the other end is directly connected to the air compressor tank. A needle valve is used to regulate the output to the brake fluid reservoir with the overflow tube plugged.
![]() Tony |
Flyin' blind
Thom
Thom 89 Coupe |
I looked at Tony's little system, saw the post about no air compressor and thought about my little keg charger. It's a keg CO2 charger that uses little CO2 cartridges: no pumping. I also carry something like this on my bike so as not to have to carry a pump. Just give the trigger a little pull and you get instant pressure. It shouldn't be too hard to plumb it into Tony's setup.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Tony, that tool is brilliant!!!
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Diss Member
I modified the Motive with a 1/4 turn ball valve in the line. Not sure why they didn't do that to begin with.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
