Location: Brighton, Michigan 1988 911 Coupe, Granite Green Metallic
Engine lid squeak
I've traced a squeak in my '88 Carerra coupe to the bracket that holds the A/C condenser to the underside of the engine lid. There is a small gap between the bracket the condenser. It seems like there should be some kind of rubber piece or something to fill this gap. If I put a wooden shim in this gap, the squeak disappears.
Has anyone else experienced this, or can you comment if there is a part that belongs between the metal bracket and condenser unit/ Many, many thanks. This squeak is quite annoying! |
If it's the center support bracket near engine lid light, a piece of adhesive backed foam goes in there.
Cooper |
That's the bracket all right!
Can you tell me the approximate thickness? I think I'll try to fabricate something that resembles the factory part. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Adhesive
Thanks, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Photo attached of subject bracket with temporary wooden shim in place.
The foam I used is a dense weatherstrip type seal. This is similar to what I have seen on the factory brackets.
Likely available at your local Home Depot, ACE, Lowe's etc. The roll I have measures ~13/16ths (20mm) wide and the foam is 1/4" (5mm) thick ![]() Good luck with your fix. Cooper
Cooper's Classy Car Care Providing Clear Bra installation, Paint touch-up, Detailing PCA/OCR since 1997 '81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter |
