Location: Brighton, Michigan 1988 911 Coupe, Granite Green Metallic
Engine lid squeak
I've traced a squeak in my '88 Carerra coupe to the bracket that holds the A/C condenser to the underside of the engine lid. There is a small gap between the bracket the condenser. It seems like there should be some kind of rubber piece or something to fill this gap. If I put a wooden shim in this gap, the squeak disappears.
Has anyone else experienced this, or can you comment if there is a part that belongs between the metal bracket and condenser unit/
Many, many thanks. This squeak is quite annoying!
Old 06-13-2014, 05:39 PM
Cooper911SC's Avatar
If it's the center support bracket near engine lid light, a piece of adhesive backed foam goes in there.
Cooper
Old 06-13-2014, 05:44 PM
That's the bracket all right!
Can you tell me the approximate thickness? I think I'll try to fabricate something that resembles the factory part.
Old 06-13-2014, 06:33 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Adhesive
Please post a pic.
Thanks,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-13-2014, 06:58 PM
Photo attached of subject bracket with temporary wooden shim in place.
Old 06-14-2014, 06:10 AM
The foam I used is a dense weatherstrip type seal. This is similar to what I have seen on the factory brackets.
Likely available at your local Home Depot, ACE, Lowe's etc.
The roll I have measures ~13/16ths (20mm) wide and the foam is 1/4" (5mm) thick
Good luck with your fix.
Cooper
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 06-14-2014, 08:04 AM
