Straight shooter
Lapkritis's Avatar
Originally Posted by dicklague View Post
Why does Innovate stuff seem to be so difficult to get working? Seems to be a lot of posts.
Because there are far more of them than any other....
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 07-24-2014, 08:18 PM
Gordo2's Avatar
Innovate LM-2 RPM Input
I finally got around to fixing the RPM input to my Innovate LM-2 wideband.
As per the Innovate instructions - I installed a 50k OHM potentiometer inline with the tachometer signal.
Instructions from Innovate: www.innovatemotorsports.com/support/manual/LM2_Manual_1.3.pdf
Once I hooked it up, I twisted the pot dial and it honed in on the correct RPM. It does appear to slightly lag actual RPM's though.
I think I will figure out the resistance where it works and simply install an inline resistor in place of the potentiometer. Too easy to accidentally bump the pot to throw off the setting.
Will post a photo of the hook up tomorrow if I have the ambition.
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 08-30-2015, 07:55 PM
