Oil level sensor question
My oil level is at the top mark on the dipstick at 180 degrees on a level surface. When I start the car on a level surface after sitting all night the gauge registers at about one third (towards the bottom). As the oil warms to 180 degrees the gauges pegs to the top. Is this a sign the sending unit is going bad?
1987 928 S4 - Black 2014 C4s 991 - Agate Grey 2014 Cayenne - Mahogany metallic |
Sounds like your oil level gauge is fine. I think your oil level is too high.
I would suggest running the oil level on the dipstick at the 1/2 point between the MIN and MAX marks when the engine is hot. Most 911s like to blow off the first quart when you run the oil level at the MAX mark, it is not needed. It just pumps the oil/oil vapor into the intake manifold. And at 180*f..the engine is just getting warm..at 210*f you are overfilled with oil. Much less smoke on start-ups and you will be amazed at how your oil consumption will drop dramatically when you add oil to keep the oil level at the mid point on the dipstick. Don't add any oil till the level on the dipstick is at the MIN mark, engine hot. Then add about 1/2 quart and drive. The oil level on the dipstick should get to about 1/2. Your oil gauge will probably show nothing when cold and about 1/2 hot when you do this. |
Member 911 Anonymous
1st, what does the dip stick read at those temps/over night?
Remember the gauge is just a guide but dip stick is what you should depend on. If they match then you have simply over filled it and OLSU is working as designed by PAG. If not, then the OLSU will need servicing or replacement. Here is my tutorial on the service/replacement. Oil Level Sending Unit: How to Service / Repair / Maintain Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
You have too much oil in the car. At 180 degrees you should be in the center of the full and add marks. The oil level will rise more if your car reaches 220 degrees and will cause oil to be sucked into the airbox, then you will have a mess to clean up. Sounds like your sending unit is fine.
I should have said I was getting a full dipstick measurement at 180+. A month ago my gauge would show just below the top mark at the same oil level. The gauge has also shown some erratic jumping at idle. Draco, do you have the link to your video mentioned in the link?
83 911 Production Cab #10
There is 1.75 Litres between Min and Max, so I would removed .75 Litre and check the dipstick again at 180
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Interesting note on the oil level sensor..in 2008 I ordered a new one from our host, part number 911 641 541 02 M100. OEM Porsche part with the gasket. $67. I still have the receipt.
My old level sensor was very wobbly and not accurate. I saw the excellent write up from Draco about rebuilding the oil level sensor and thought why would you do that? They are not that expensive, are they? Same part number OEM Porsche sensor now is $158! |
Just click the pic, it will link you to the video on photobucket.
Yeah, $158, I'm a cheap basturd, that's why :-)
Well I drained abot .75 litres of oil to get to the mid-point on the dipstick when hot. The gauge moves from the low end of the guage at startup to slowly pegging the guage at full temp. Probably the sensor.
I cleaned the area around the sender and the wire contacts, and still the same symptoms. I need to shrink wrap the center lead. I ordered a sender and gasket and will follow-up. Before: ![]() After:
Oil level.
Back to your original comment and question, oil expands when it gets hotter, hence the difference in oil level between cold and hot.
Decided to take off the ground screw and the copper male tab. This was the issue. I used 600 grit emory and sanded down the corrosion and oil buildup on the contact and the bottom of the nut. All is working well now. Also shrink wrapped the other contact.
Caveman Hammer Mechanic
The Handbook of Industrial Oil Engineering: A Reference Book of Data ... - John Rome Battle - Google Books Or http://nvlpubs.nist.gov/nistpubs/jres/5/jresv5n5p985_A2b.pdf
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 07-20-2014 at 08:02 AM.. |
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
I had no confusion about the oil level on the dipstick rising as the oil heated. It was that the dipstick level and the oil gauge level had a difference. The gauge was reading higher than the actual on the dipstick. When the oil level on the dipstick is at the midpoint, the gauge is now at the midpoint.
Congrats, a much easier and cheaper fix
![]() In your "before" pic, was that oil on the exterior? If so, you may want to consider replacing the gasket or just maintain it from fouling up your ground. Lesson Fellas, Clean Your Grounds.
