Oil temp sender connector terminal
This seems like a dumb question but what size/type is the oil temp sender round connector push-on terminal? I have small, medium, and large sizes and NONE of them fit! It's bigger than the large size. Is there an extra-extra large size available somewhere?
DD summer/winter: 2000 Boxster S DD spring/fall: 914-6 w/ 3.0L SC Dual Webers (For Sale) http://imgur.com/a/k0Wtl - My 914-6 Build/Project Story |
On which car?
On my 3.0 I recall just pushing a bit harder did the trick.Or use a screwdriver to slightly enlarge the gap.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
ROW '78 911 Targa
I have them. PM me with your info and I can mail you one or two.
ROW '78 911 Targa
Or,
Brass .312” Flag Receptacle Here: http://www.easternbeaver.com/Main/Elec__Products/Terminals/Open_Barrel/open_barrel.html $20 minimum I believe from Japan. Mouser has similar but not in brass. Sent from my iPhone using Tapatalk
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 07-16-2014 at 08:17 AM.. |
The .312 terminal is the same that is used on an H4 headlight.
Motorcycle Spade Terminals Part # YFST1416N Open Barrel I also have 2 or 3 leftover from when I converted to ceramic H4 connectors a few weeks ago, so if you can wait, pick them up when you come by for the muffler. Or, if you happen to be running H4 bulbs, you can upgrade the connectors with ceramic, and have them toss an extra female terminal or 2 in the order: Headlight connectors Get the orange covered ones.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
ROW '78 911 Targa
They are in the mail to you.
![]() Sent from my iPhone using Tapatalk
