Discseven's Avatar
Originally Posted by Jack Stands View Post
When you install the new motor and fan assembly, check the positioning of the fan in the blower housing so it doesn't hit or rub against the plastic.
Nice Jack. I'll add checking to make sure the wiring is connected to spin the blower in the right direction.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-19-2014, 01:45 AM
Heck, I’m only 5 not 71!
targa80's Avatar
[QUOTE=Discseven;8170297]I had same melt down with mine.
A follow up on Jacks note about removing blower... the allen screw securing blower to shaft on mine was sealed with some sort of hard wax. I'm not drilling it out in the photo below... I'm just poking the stuff with a drill bit... and it came out. The blower took some time getting off the shaft.
[QUOTE]
The hard wax is a red locktite which prevents the screw from coming loose during operation.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 07-19-2014, 05:47 AM
Discseven's Avatar
Thanks Pat. I thought it was a rust inhib.
Karl ~~~
Old 07-19-2014, 06:05 AM
El Duderino
tirwin's Avatar
I recently got a new motor. I was trying to get that dang Allen screw out and the Allen wrench broke right off flush inside the screw. Talk about pissing me off!
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 07-19-2014, 06:10 AM
6 cylinder symphony
+1 on the fuse. I installed one on my car when I re-built the front fan.
On the squirrel cage. Soak soak soak in your favorite penetrating agent. For a few days. Right at the tip of the shaft, corrosion build up won't allow you to just pull the squirrel cage off. And, the cage is delicate. After soaking, use a dremel with a small wire brush to try and clean up that tip area. Do not use a puller of any kind - you will damage it. Finally - coat the shaft with anti-seize before re-installation - just in case.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
88 Carrera, Guards Red
azhodge's Avatar
anyone know where to get those dang clips that hold the two halves of the condenser fan housing together? one was missing and another one flew off into the never to be found corners of my garage...
Old 08-12-2014, 01:58 PM
Go-Kart Mozart
JAR0023's Avatar
Originally Posted by MConn View Post
If you don't want to cut your harness, the Porsche part number for the inline fuse is 911612077 - kind of pricey
I think I had to use a 10 amp because of starting current, but I'm using a footwell blower motor.
Mike
10 amps here as well. Factory harness showed up with a 7.5 and it blew more times than not when I turned on the A/C. I bumped up to a 10 amp and that one's been in the car ever since. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 08-12-2014, 02:19 PM
MConn's Avatar
Our host sells these -
Tension Spring
Mike
The more I learn, the less I know.
Old 08-13-2014, 04:54 PM
Jack wrote:
>>I found it easiest to chuck the motor housing in a vice and tighten down until the housing is distorted enough to crush the armature against the outer housing, preventing it from turning.
I'll bet that felt good!!! I hate these dangerous, ineffective, noisy, unreliable and expensive Bosch fans that I'm slowly replacing with (inverse of all previous adjectives) GM fans.
Chuck.H
'89 TurboLookTarga, 380k miles
Old 08-14-2014, 05:08 AM
azhodge's Avatar
just tried to order the 911612077 fuse kit from our sponsor. $48 dollars was bad enough, but after ordering they informed me that it is no longer stocked in the US and must come from Germany. But for a cool additional 20%. thats it for me. I will make my own for eight dollars. won't be a pretty but it will work.
Old 08-14-2014, 05:51 PM
