Platinum Member
dad911's Avatar
Originally Posted by Bob Kontak View Post
Regarding cinder blocks, even for a don't ever do this ever setup, Karl at least has the weight spread across six points.
Now that truck............kind of looks like a mousetrap.
That's the problem. You never point load a cinder block. They are meant for the load to be evenly distributed, in a bed of mortar.
Old 07-20-2014, 01:03 PM
Got paid mulch........
Originally Posted by dicklague View Post
I made this wrench to more easily advance the engine 120 degrees when doing a valve adjustment. I welded an old 19mm ratchet head wrench onto the end of a section of tube.
Dick,
Your tool is the upgraded version welded to a nice handle. Mine is the poor man's version (Home Depot wood paddle).
I used the above contraption for turning this high compression engine that I rebuilt for a friend (a landscaper) for some mulch my wife needed for her tiny garden.
Old 07-20-2014, 01:40 PM
I like it!!
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 07-20-2014, 02:06 PM
Which one?
I like it!!
The tool or the engine?
Tony
Old 07-20-2014, 02:50 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I like it!!
I gotta say, this tool has taken the lead given my humble opinion.
1981 911SC Targa
Old 07-20-2014, 05:10 PM
Bob Kontak's Avatar
How many more times you think we need to tell Karl not to use cinder blocks?
Six more times? How bout fifty?
1981 911SC Targa
Old 07-20-2014, 05:12 PM
Banned
I was thinking that seventeen more times might make an impression.
Old 07-20-2014, 05:32 PM
Bob Kontak's Avatar
It's the wrong thing to do. Karl was aware of that when he set it up.
He rolled the dice and lived.
The end.
I would rather see more discussion on tricking out the volley ball.
Was it a German volley ball? If you did write Wilson on it, should it be in Porsche font?
1981 911SC Targa
Old 07-20-2014, 06:43 PM
Discseven's Avatar
And I thought my cinder blocks would take "Top Tool." Damm Bob... very disappointed here. However, I do appreciate all the love from you guys as in "you ass-hole Karl, cinder blocks will kill you." I did make it past that gauntlet (And very astute on the weight spread Bob. That was key that ONLY YOU noticed.) The V-ball... made in Zuffenhausen --- I know it's hard to make the "Made in" print out. Top Tool (after cinder blocks IMHO): Tony's tape-wrench used to make 911 mulch.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-21-2014, 09:21 AM
Bob Kontak's Avatar
Edited - personal attack removed.. -Z-man. It's all good. You do it again, you are on your own, Bro.
You know, I had a stick that I used to prop the trunk hood up. Made in Wiessach printed on it. (Prototype test stick - 959 part number)
Here is an idea from Tippy I am shamelessly stealing. I have used WD 40 on old ratio volume knobs (on the inside of the radio/pre-amp/amp) with great success.
Originally Posted by Tippy View Post
I bought a busted clock here from a Pelicanite. I used an old trick my dad used for restoring cars... Simply opening clocks up and spraying WD-40 in them.
The clock worked.....
1981 911SC Targa
Old 07-21-2014, 12:42 PM
Discseven's Avatar
Originally Posted by TBone78SC View Post
Not sure what the original tool was supposed to be, but this homemade device is pretty effective...
Tom, I'm assuming the top is a plug of some sorts and the bottom thing-a-ma-Tom the tool --- nice BTW! Call me dumb-dumb... but what is the "plug?" Looks familiar but I can't place it.
Karl ~~~
Old 07-21-2014, 04:46 PM
83 911 Production Cab #10
JJ 911SC's Avatar
One of the 2 plugs on the oil thermostat for the front oil line by the passenger rear wheel.
I use a "Toonie" ($2 coin) clamp in a vise grip, one came off and the other one bent the "Toonie".
Who Will Live... Will See
Old 07-21-2014, 06:31 PM
Tony
the wooden handle!!
03 Boxster
Old 07-21-2014, 07:23 PM
Discseven's Avatar
Method - Sealing Windshield to Car
Sealing windshield to car with Ace's mat black electrical tape. (Not 3m's tape which is more glossy.) Definitely won't pass Concourse inspection but if you don't know it's there, probably wouldn't notice it (given black-on-black materials.) No more dripping from under dashboard and subsequent swampy floor mats.
Karl ~~~
Old 07-22-2014, 06:35 AM
AVIMAX's Avatar
Here is a topic I posted last year about temporarily fixing my alternator. I was planning to fix it this past spring, but I haven't done it yet. About 4,000 ams later and the alternator is still working fine. Maybe I'll fix it properly next year. I guess this qualifies as alternative thinking.
temporary alternator fix - cheating
'86 Carrera Targa
'74 MGB
Old 07-22-2014, 10:05 AM
