Alternative Thinking - Methods & Tools
This thread is about:
As thread starter, I'll not post the first image... someone else please start us off >>>
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 07-18-2014 at 07:48 AM.. Reason: Learning to spell |
Fleabit peanut monkey
Starting small......
Posted this before. On my 81SC, which has metal fuel lines, when I use a long standard or t-handled 3mm allen wrench to adjust a/f mixture the short end invariably impacts the immovable lines when rotating. This requires pulling the wrench out and repositioning. Kind of a PITA. Also, really long allen wrenches can hit the ceiling not allowing the turn into the hole. I whacked off a standard 3mm wrench , drilled a hole in the end of a allen head cap bolt (I think that's what they call it) and epoxied it into the hole. Larger allen wrench can be re-positioned without pulling the 3mm out. ![]() If you open it up to car repairs in general, I bet this thread would take off. Everybody here has other cars - and success stories.
1981 911SC Targa |
I keep a drawer full of cheap Chinese/indian wrenches so I can heat and twist them into unique shapes to reach oddly placed fasteners. Last time I recall doing one was to remove/fasten heat exchangers. SSI,s and 993 HE,s with rotated flanges to put a 3.6 in an early car .
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
Me too. I bend them with heat, slim them down with the angle grinder. Cut chunks out to make them into flare wenches. I give them death and if they break it's only a dollar or two. Remembering... I once had the broken end of a ring spanner on a nut and got more torque with a pipe wrench griping the broken ring spanner. Nuts that slip on ring spanners; a friend said he welds the spanner to the nut so it doesn't slip then throws both away. |
1/2 inch was the correct size but the bottom bolts had corroded to the point where they were not 1/2 inch. Six sided S&K 1/2 socket would not work. So I hammered, literally, a 12MM el-cheapo 12 point socket onto the "hex" head and got it out.
1981 911SC Targa Last edited by Bob Kontak; 07-18-2014 at 04:16 PM.. |
Tired Member
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
2-for-1: Lift ramp (made impromptu at Grandma's house.) Vollyball for dead hood shocks.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Hi Karl,
Not trying to be the safety police, but I've been told that concrete blocks can break apart when used like that. I have used them a couple times to get extra height to pull my engine and had no issue. Now that I know that though, I will figure something else out instead. Rutager
Rutager West 1977 911S Targa Chocolate Brown |
One other thing Karl, you need to write "PORSCHE" on that volley ball and charge yourself a hundred bucks!
Official "alternative" part for front hood struts.
On safety police matters... good comment on your part Rutager. I've heard the same. Given the weight of the front (with no gas) and the condition of the blocks, I had no problem with my safety. (Grandma did.)
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
![]() ^^^^^ Solder a piece of insulated 12ga wire to the pickup tool for flexibility.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 07-19-2014 at 10:29 AM.. |
Member 911 Anonymous
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Concrete blocks are made of sand and small stones and a tiny amount of concrete dust...and pressed together...then baked.
They are very brittle!! Using them for support under a car is suicide!! Please don't. Bob
Bob Hutson |
Don't try this at home.......
Karl,
Don't ever try that hollow blocks again!!!!! We need you for more dash recovery projects. I think this guy working under the truck was also from Florida (joke). ![]() Tony |
#147 of 2096
Hi to all...
Last week a technician died at a friend of mine shop. A vehicle roll from the blocks and he was under the vehicle. Simply is way too risky.
#147 of 2096 |
Wingnut
Not sure what the original tool was supposed to be, but this homemade device is pretty effective...
Tom There's a hole in my garage where the money goes... |
Banned
Regarding cinder blocks, even for a don't ever do this ever setup, Karl at least has the weight spread across six points.
Now that truck............kind of looks like a mousetrap.
1981 911SC Targa |
![]() This tool is great for valve adjustments......much better than feeler gauge. Tighten the valve adjustment screw and back off 36 degrees which is .1mm.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
![]() I made this wrench to more easily advance the engine 120 degrees when doing a valve adjustment. I welded an old 19mm ratchet head wrench onto the end of a section of tube. ![]() Here is the wrench in place and in use. The handle is a bit long, but does a good job. Makes advancing the crank very easy.
