How do you remove the fan from the housing?
I have the fan, shroud, and alternator removed from the car. I was thinking that I might paint it while it's out - while working on other projects.
How do you remove the fan. I was thinking that you just remove the nut and pull but I thought I'd ask before breaking something. I don't see any nuts or bolts from the back side.
Thanks!
Old 07-28-2014, 10:34 AM
tobluforu's Avatar
Help needed removing alternator from fan housing
Old 07-28-2014, 11:13 AM
47silver's Avatar
Don't paint it, it will just chip and look horrible in a week
Old 07-28-2014, 11:14 AM
Thanks! I think I understand. It just needs a little jolt and the fan should slip off the alternator shaft.
I haven't decided for certain about painting but will definitely be giving it a deep cleaning.
Old 07-28-2014, 02:03 PM
Discseven's Avatar
A recent post for you concerning fans & finishes Vern: Metal Preservatives Testing on Polished Cooling Fan
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-28-2014, 02:17 PM
Walt Fricke's Avatar
Removing the alternator is not quite the same as removing the fan. I read that post to deal with removing the alternator itself after you have removed the bolts holding it to the housing.
If you want to paint the fan, you can remove just it from the alternator shaft.
In theory, once you remove the fan pulley nut you should be able to pull the fan off of the alternator shaft with your fingers. It is locked to the shaft by a Woodruff key in the usual slots. However, it seems they are always too tight for this.
What I have found useful is to use a chatter gun - an air chisel with a flat, wide ended tool in it, so it just vibrates the end of the shaft when applied axially to the shaft where it won't damage any threads, and doesn't chisel it, while you use your other hand to put pressure on a blade pulling outward. Slides right off. Attempts, even with soft wood pieces, to drive the fan off can end up breaking a chip out of some part of the fan.
Old 07-28-2014, 02:26 PM
If the fan doesn't pull off easily, I may try some penetrating oil. I have used a mix of 50/50 ATF and acetone with great success.
As far as painting....I'm inclined to leave the fan alone but maybe paint the housing and only go a couple shades darker than stock. I'll have to see how the fan looks cleaned up but it's in pretty good shape now.
Old 07-28-2014, 04:30 PM
Immature Member
dentist90's Avatar
Method I used was to loop heavy wire (coat hanger) thru opposing holes and apply tension with a puller. When I had enough tension I thought the wires were going to snap I tapped the fan hub with a plastic mallet and -'ting' - it popped off nicely. Do yourself a favour and apply antiseize to the shaft before you reinstall it
1984 Carrera Coupe = love affair
1997 Eagle Talon Tsi = old girlfriend (RIP)
2014 Chrysler 300 AWD Hemi = family car
"Lowering the bar with every post!"
Old 07-28-2014, 07:00 PM
Go-Kart Mozart
JAR0023's Avatar
You can use a tap and thread two of the holes shown. 5 or 6mm. Not for sure off the top of my head. Threads are about half depth but plenty to use to screws and press the fan right off. Can't take credit for it. Tip I picked up in a thread here. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 07-28-2014, 08:58 PM
